BX2200 loader hydraulic hoses
   / BX2200 loader hydraulic hoses #1
rosey
Appomattox, Virginia (Central Va.)
Kubota BX2200
I just wanted to pass this on to those of you who are going to re-install your front loader. make sure that you carefully reattatch your hydraulic hoses so that they do not rub or bind against each other especially when the loader is in the full lift position. I noticed some wear on one of my hoses where one had been rubbing against another and also had one hose pull loose from the coupler. Just take your time when reattatching the loader hoses and test them out by raising and lowering the loader a few times to make sure that things are smooth.....will save you aggravation.
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
UNUSED RAYTREE RMDM72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
