Bx2200 Ice alert
/ Bx2200 Ice alert #1
chocolatehauler
Harbor Springs Michigan
Bx2200
Today while snowblowing the grill that covers the battery Iced up, and caused the temp to rise up to the red line. Glad I was watching the gauges. I don't have a cab so snow blows everywhere when the wind is up. Just and alert that others might want to look out for. over heating is a engine killer. /forums/images/graemlins/shocked.gif
/ Bx2200 Ice alert #2
Yea, you need to watch out for a similar thing in the summer when the "stuff" flies when you are mowing. It's really easy to clog up the grill between your feet and cause a similar air flow problem. Dandilion seeds are what I have the most problem with...
/ Bx2200 Ice alert #3
chocolatehauler... Don't you know that it is Spring??? Put the snowblower away and get out the mower /forums/images/graemlins/grin.gif
John
/ Bx2200 Ice alert #4
</font><font color="blue" class="small">( Today while snowblowing the grill that covers the battery Iced up, and caused the temp to rise up to the red line. )</font>
Are you sure this was the cause? I do have a cab and one of the standard equipment items was a vinyl shield that completely covers this grille. This helps keep the heat in the cab. I haven't had the tractor long but do have 15 hours on it, all of which were done with that cover in place.
Perhaps it was the filter directly in front of the radiator that froze? This would keep air from circulating through the radiator and possible overheat the engine. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
/ Bx2200 Ice alert
I was debating as to takeing it and putting it away when we got hit with better than a foot of snow. now I don't know when is the right time to take it off /forums/images/graemlins/tongue.gif
/ Bx2200 Ice alert
Are you sure this was the cause? )</font>
If you look behine the cover you will probley see a cover on the bottom that was taken off so the air can get in. /forums/images/graemlins/smile.gif
/ Bx2200 Ice alert #7
SPRING? we used to have that but they cancelled it. still cold and crappy here in western n.y. /forums/images/graemlins/frown.gif
/ Bx2200 Ice alert #8
</font><font color="blue" class="small">( [
If you look behine the cover you will probley see a cover on the bottom that was taken off so the air can get in. /forums/images/graemlins/smile.gif )</font>
That might explain it, I'll check tomorrow! /forums/images/graemlins/blush.gif
/ Bx2200 Ice alert #9
If you have the grill cover on with the cab, be sure you take the floor cover off from under the battery. Otherwise the engine can't get any cooling air to it.
/ Bx2200 Ice alert #10
</font><font color="blue" class="small">( If you have the grill cover on with the cab, be sure you take the floor cover off from under the battery. Otherwise the engine can't get any cooling air to it. )</font>
Okay, got a chance to check today and you are right. There is no bottom plate installed under the battery so it must breathe from there. Now to call the dealer and find out where the bottom plate is! I may never use it but I think I should probably at least have it in case I want it down the road.
/ Bx2200 Ice alert #11
You'll need it in the summer time when you mow the lawn. It needs to be in place or you'll have a lot of problems with clogged screen and radiator.
/ Bx2200 Ice alert #12
</font><font color="blue" class="small">( You'll need it in the summer time when you mow the lawn. It needs to be in place or you'll have a lot of problems with clogged screen and radiator. )</font>
Well, thanks to all of you guys! If it weren't for you I would never have known about this plate since the tractor didn't come with it. I have spoken to the dealer and he said they take them off when they put on the cab. I asked him to get me one along with the handles on the fenders (which they take off to install the cab as well) and he said he would.
I'll definately install the plate for the summer mowing season.
/ Bx2200 Ice alert #13
The cab will really help with the cold.....you might check the bolt in the fuel fill area outside the cab and saw it down to the top of the nut. That bolt will help you to loose weight by removing flesh if you dont. I used a sawsall to cut the bolt off flush with the nut and then filed it down to smooth it out.
Enjoy! /forums/images/graemlins/laugh.gif
/ Bx2200 Ice alert #14
If you saw the bolt off, you won't be able to reinstall the handles in the summer. Personaly speaking, I haven't had a problem with mine. I take my cab off in early spring every yr.
/ Bx2200 Ice alert #15
Hi Ray:
I thought about taking the cab off for the summer but between the wires, heater hoses (I have a Sims cab with the rear mounted heater) and all that good stuff I decided against it. I can always redirect the defroster so it blows on me....call that a poor man's AC.
I figure the cab is on for the duration!
/ Bx2200 Ice alert #16
I solved the disconnect problem. I have all the wiring going into an amphenol connector. It plugs into the side of the dash. The heater is connected via quick connects under the hood. The lights, wipers, heater, and stereo all disconnect in under 5 minutes. My tree branches are to low to mow with the cab on. In the summer I just use a chain hoist to remove the cab.
/ Bx2200 Ice alert #17
Ray....good thoughts....I may have to look into the quick disconnects for the heater hoses and the electrical....I have enough room in my garage to use my comealong and lift the cab off.....would be cooler!
The other alternative is to get a muck larger tractor with A/C and stero.....have to work into this slowly otherwise the better half will be using me for tire loading!
Thanks
/ Bx2200 Ice alert #18
Re: Bx2200 Ice alert - Off Topic
Hi Frank,
Sorry to hear about being cold and crappy in Western NY. Here in Syracuse it's Summer today. Supposed to get up to 40F with some sun. Gotta find the Hawaiian shirt.
Seriously, do you have a snowblower? I know you replied to one of my posts, but don't think you said. I am waiting on delivery of a B7800 with rear SB, FEL, RM.
Kind of off topic, so you can Email if you would like.
Thanks,
Frank
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
1995 CUSHMAN TURF HAULER (A64280)
1995 CUSHMAN TURF...
