Bx2200 Ice alert
   / Bx2200 Ice alert #1
chocolatehauler
Harbor Springs Michigan
Bx2200
Today while snowblowing the grill that covers the battery Iced up, and caused the temp to rise up to the red line. Glad I was watching the gauges. I don't have a cab so snow blows everywhere when the wind is up. Just and alert that others might want to look out for. over heating is a engine killer. /forums/images/graemlins/shocked.gif
   / Bx2200 Ice alert #2
Yea, you need to watch out for a similar thing in the summer when the "stuff" flies when you are mowing. It's really easy to clog up the grill between your feet and cause a similar air flow problem. Dandilion seeds are what I have the most problem with...
   / Bx2200 Ice alert #3
chocolatehauler... Don't you know that it is Spring??? Put the snowblower away and get out the mower /forums/images/graemlins/grin.gif
John
   / Bx2200 Ice alert #4
</font><font color="blue" class="small">( Today while snowblowing the grill that covers the battery Iced up, and caused the temp to rise up to the red line. )</font>
Are you sure this was the cause? I do have a cab and one of the standard equipment items was a vinyl shield that completely covers this grille. This helps keep the heat in the cab. I haven't had the tractor long but do have 15 hours on it, all of which were done with that cover in place.
Perhaps it was the filter directly in front of the radiator that froze? This would keep air from circulating through the radiator and possible overheat the engine. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Bx2200 Ice alert
I was debating as to takeing it and putting it away when we got hit with better than a foot of snow. now I don't know when is the right time to take it off /forums/images/graemlins/tongue.gif
   / Bx2200 Ice alert
Are you sure this was the cause? )</font>
If you look behine the cover you will probley see a cover on the bottom that was taken off so the air can get in. /forums/images/graemlins/smile.gif
   / Bx2200 Ice alert #7
SPRING? we used to have that but they cancelled it. still cold and crappy here in western n.y. /forums/images/graemlins/frown.gif
   / Bx2200 Ice alert #8
</font><font color="blue" class="small">( [
If you look behine the cover you will probley see a cover on the bottom that was taken off so the air can get in. /forums/images/graemlins/smile.gif )</font>
That might explain it, I'll check tomorrow! /forums/images/graemlins/blush.gif
   / Bx2200 Ice alert #9
If you have the grill cover on with the cab, be sure you take the floor cover off from under the battery. Otherwise the engine can't get any cooling air to it.
   / Bx2200 Ice alert #10
</font><font color="blue" class="small">( If you have the grill cover on with the cab, be sure you take the floor cover off from under the battery. Otherwise the engine can't get any cooling air to it. )</font>
Okay, got a chance to check today and you are right. There is no bottom plate installed under the battery so it must breathe from there. Now to call the dealer and find out where the bottom plate is! I may never use it but I think I should probably at least have it in case I want it down the road.
2018 Bobcat T650 Skid Steer Loader (A49251)
2018 Bobcat T650...
2015 Dodge Ram 1500 Crew Cab Pickup Truck (A46684)
2015 Dodge Ram...
2006 Toyota Tundra 4X4 Pickup Truck (A46684)
2006 Toyota Tundra...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
305 E2 CR, Open Rops Excavator (A47371)
305 E2 CR, Open...
2009 MACK PINNACLE CXU613 TANDEM AXLE  DAY CAB (A45678)
2009 MACK PINNACLE...
