BX2200 hydro pedal pivot access?
   / BX2200 hydro pedal pivot access? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My hydro pedal is sticky, and the pivot won't take grease. I have to take it apart and clean up the pivot pin so I can get it to take grease again, but I can't figure out how to get to the pivot without tearing the tractor in half. Any clue?
   / BX2200 hydro pedal pivot access? #2
You could try taking the zerk out and putting some penetrant in and letting it set a while.
   / BX2200 hydro pedal pivot access? #3
I find that when a zerk won't take grease I put in a new one and that generally solves the problem. Doesn't cost much to try and may be easier than tearing the tractor apart. Just a thought.
   / BX2200 hydro pedal pivot access? #4
One could try a grease fitting rejuvenator.
You fill it with penetrant,attach it to the zerk,and swat it with a hammer,forcing the obstruction out of the joint.
Google grease fitting rejuvenator for examples.
Good Luck!
   / BX2200 hydro pedal pivot access? #5
My BX22 takes grease VERY slowly. I thought mine wasn't taking any, but it does, Just so slowly I thought it wasn't. Not saying yours isn't plugged though.
Kim
I did remove the zerk, and it works fine. I even put in a new one - the pin appears to be tight around the fitting and I can't get the grease to go in. I think I hit it with some kind of penetrating lube, but I might be wrong. I'll have to try again - maybe a good soak with Kroil will do it.
   / BX2200 hydro pedal pivot access? #7
Did you try putting grease in while rocking the directional pedal back and forth? Sometimes this helps in my limited experience...
   / BX2200 hydro pedal pivot access? #8
put some white grease thats what i use and the pedal wont stike
Cool - how did you get the pedal off to put the grease inside the pivot? (my original question)
I tried everything.
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2016 Ford F-250 (A50120)
2016 Ford F-250...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
