BX2200 hydro pedal pivot access?
   / BX2200 hydro pedal pivot access? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My hydro pedal is sticky, and the pivot won't take grease. I have to take it apart and clean up the pivot pin so I can get it to take grease again, but I can't figure out how to get to the pivot without tearing the tractor in half. Any clue?
   / BX2200 hydro pedal pivot access? #2
You could try taking the zerk out and putting some penetrant in and letting it set a while.
   / BX2200 hydro pedal pivot access? #3
I find that when a zerk won't take grease I put in a new one and that generally solves the problem. Doesn't cost much to try and may be easier than tearing the tractor apart. Just a thought.
   / BX2200 hydro pedal pivot access? #4
One could try a grease fitting rejuvenator.
You fill it with penetrant,attach it to the zerk,and swat it with a hammer,forcing the obstruction out of the joint.
Google grease fitting rejuvenator for examples.
Good Luck!
   / BX2200 hydro pedal pivot access? #5
My BX22 takes grease VERY slowly. I thought mine wasn't taking any, but it does, Just so slowly I thought it wasn't. Not saying yours isn't plugged though.
Kim
I did remove the zerk, and it works fine. I even put in a new one - the pin appears to be tight around the fitting and I can't get the grease to go in. I think I hit it with some kind of penetrating lube, but I might be wrong. I'll have to try again - maybe a good soak with Kroil will do it.
   / BX2200 hydro pedal pivot access? #7
Did you try putting grease in while rocking the directional pedal back and forth? Sometimes this helps in my limited experience...
   / BX2200 hydro pedal pivot access? #8
put some white grease thats what i use and the pedal wont stike
Cool - how did you get the pedal off to put the grease inside the pivot? (my original question)
I tried everything.
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A52577)
2002 WESTERN STAR...
2022 FORD F-250 SUPER DUTY (A52472)
2022 FORD F-250...
Toro Workman Utility Cart (A51694)
Toro Workman...
2012 Harley-Davidson FLHX Street Glide Motorcycle (A50324)
2012...
2013 Ford Flex SUV (A50324)
2013 Ford Flex SUV...
