For some reason my bx keeps shearing the roll pin in the front drive shaft. has anyone else had this problem or heard of such? I can't see how the pin is shearing as the shaft is splined.
I have a 2010
BX25 with 2300 hours on it. The front pin joining the front pinion shaft to the driveshaft snapped for the second time, dropping the driveshaft to the ground. There seems to be no binding and plenty of room for forward and backward movement on the splines. The other end of the driveshaft fits into another spline, with no pin.
I was just hauling buckets full of rocks and had the
BX25 locked in 4x4.
It makes no sense, as even under the weight of the load, operating in 4 wheel drive and the splines are not binding, that there SHOULD be any loading on the pin. I also had assumed the original pin just lost its cotter, and maybe the second pin did too as I never found either pin to see if it fractured or the cotter was missing.
I will probably install a 6mm bolt this time, wait to see what happens.
