BX2200 front drive shaft pin sheared
/ BX2200 front drive shaft pin sheared #1
bxbuster
Minnetonka, MN
BX2200
For some reason my bx keeps shearing the roll pin in the front drive shaft. has anyone else had this problem or heard of such? I can't see how the pin is shearing as the shaft is splined.
Thanks for any replies!
/ BX2200 front drive shaft pin sheared #2
I would check the front axle to make sure the shafts inside are turning without problems....if you have a tooth broken off inside, it could be getting caught in the gears. BTW, I don't think that front drive shaft is splined...I could be wrong though. Are you using the right roll pins? They may be a harder grade.
/ BX2200 front drive shaft pin sheared #3
Are you using chains on the front?
/ BX2200 front drive shaft pin sheared #4
I would have to guess you are shearing the pin with an axial (along the length of the shaft) load, not a torque, since, as you pointed out, the joint is splined to carry the torque. One of the joints in that drive line is meant to slip axially. I think it's the one that is forward of the supported U-joint under the engine. Try cleaning an lubricating that spline the next time the pin fails.
/ BX2200 front drive shaft pin sheared #5
Tagging - on to Gamemasters?
If your'e using chains on the front tires, while engaged in 4WD, your stressing the front drive train, because the front axle and tires spin faster than your rears (it's called slippage) The drive train ratio (front:back) is designed to have the front tires lead the machine. Front chains ****** slippage.
I'm not using chains. The first time it sheared I was hauling boulders that were definatley at the capacity of the loader as I was riding around the yard on the front tires. Quite a commical ride but hey these things are tough. The pin didn't acutally shear then but sometime later while operating on flat ground. I can't see how chains could affect the pin as the drive shaft is splined. It's a vrey odd setup if you ask me. A yolk on a splined shaft and then it's pinned with a roll pin. The only way I can see the pin shearing is if the stress is causing the yolk to be pulled or pushed on or off the shaft. Even if that is the case the other end should be able to move to accomodate. I'm wondering if the advice to grease up the other end is the answer here. Otherwise I'm wondering if the stops on the front axle have bent or worn enough to cause the shaft to extend beyond its limits. The second time it sheared off I was driving down a gravel driveway and BANG! Anyway, it's been good so far for the plowing season I was more curious if anyone had similiar experiences and could point me to the cause. One other thing to note is the roll pin is not something you pick up at the hardware store. It must be some type of metric pin. I had to take a standard pin and cut a larger groove in it.
Thanks all for your replies and if anyone else has anything to add I'd appreciate it.
Mike
/ BX2200 front drive shaft pin sheared #7
If the rear wheels are not getting traction, then most likely you would break an axle or gear. Check that your front axle brackets are tightly secured to the frame. I have seen many come loose and cause this problem. The roll pin only keeps the shaft from sliding forward or backward. No tension against pin.
/ BX2200 front drive shaft pin sheared #8
bxbuster, I used to have this problem frequently losing the pins got to where carried spares in tool box or breaking the propeller shaft (5) so far then front pinion shaft broke so had to remove and replace all bearings, gears, seals. Expensive. what I found was the front axle case and case boss and front axle bracket worn to point wobble of axle would bind and break something Kobuta says replace front housing. Had pictures but lost when computewr quit.
Place a jack or blocking under front frame to where wheels just off ground move axle forward or rear ward to check wobble, the front axle bracket held by 2 bolts and no way of lubing bushing 4 bolts for rear axle bracket holds the pinion shaft ,most likely worn also.Just my problem if some one had men tioned earlier would of cost my expense of a couple thousand. ken
/ BX2200 front drive shaft pin sheared #9
big johnkub The pins are mashed by the pinion jambing backwards toward transmission and thanks for the help on earlier post of engine problems. ken
/ BX2200 front drive shaft pin sheared #10
It's been 2 weeks did you locate problem of pins snaping on front end?
Sorry for the huge delay in getting back to this post but I'm in the process of building a new home. I have not had any sheared pins since the last incident. I have made it through a season of plowing and snow blowing etc and have started hauing tons of soil and boulders again with any drive shaft probelms. I checked the axle wear as instructed and everything appears to be in great condition with no play noted. I have noticed though an odd almost grinding coming from the front end only when in 4 wheel drive and only with a heavy loaded bucket. I really don't know how to describe the feeling and grinding isn't really accurate. It's almost like a binding or snapping feeling like rocks are caught in the gears or something. I checked the axle fluid and it's clean as a whistle so I doubt I have metal in the gears. I can't see how this is related to the shearing driveshaft pin but I thought I'd mention it in hopes someone would have an opinion on the matter.
/ BX2200 front drive shaft pin sheared #12
There was a member about three years ago or I think that was about when it was, that was have this problem with his BX. The best that I can remember it needed grease on the end of the shaft at the transmission end. That may not be right, but I think that was what it was. Anyway he found out what the problem was a fixed it. If you do a search you might be able to find it.
/ BX2200 front drive shaft pin sheared #13
Just had this happen on my BX23. It happened once before on my BX2200.
The yolks do not have a zerk and it is hard to grease the splines without removing the pin/yolk.
I think the problem is not enough grease on the splines, under load it binds and pushes or pulls on the yolk and shears the pin.
Advice: Spray grease the yolk and spines regularily or plan on replacing shear pins.
/ BX2200 front drive shaft pin sheared #14
I have a 2010 BX25 with 2300 hours on it. The front pin joining the front pinion shaft to the driveshaft snapped for the second time, dropping the driveshaft to the ground. There seems to be no binding and plenty of room for forward and backward movement on the splines. The other end of the driveshaft fits into another spline, with no pin.
I was just hauling buckets full of rocks and had the BX25 locked in 4x4.
It makes no sense, as even under the weight of the load, operating in 4 wheel drive and the splines are not binding, that there SHOULD be any loading on the pin. I also had assumed the original pin just lost its cotter, and maybe the second pin did too as I never found either pin to see if it fractured or the cotter was missing.
I will probably install a 6mm bolt this time, wait to see what happens.
/ BX2200 front drive shaft pin sheared #15
YA472 Have you looked at the front bolster shaft. there is a grease joint that no one greases and it causes wear in area where the pin holds the axle to the frame. this in turn allows the front axle to bang against the pin and breaks it . this pin in only to keep the shaft from falling out a condition which you have experanced.
tighten the bolt then read the book . or the wallet will collapse also.
/ BX2200 front drive shaft pin sheared #16
I have never greased the front axle pivot bolt, so I better check that out tomorrow, thank you. I will also check for movement, though I haven't noticed it when operating the tractor. There is a tremendous amount of free play in the splines, but will check the limits too. thanks.
/ BX2200 front drive shaft pin sheared #17
Yup, just had a peeky-boo at the front axle. There is no grease nipple, and the front axle is solid with no perceptible movement with the front tires elevated off the ground. Everything feels smooth and loose. Again, the amount of vertical axle movement is minor compared to the free play in the spline. There is plenty of free movement on the unpinned spline joint, where it attaches at the steady bearing. I can't see any issue. Tomorrow I will install a 6mm x 50mm bolt with a nylon locking nut, and see if that lasts the next nine months. I will also slip some grease on the splines and keep an eye on it. Only 2300hours, near constant locked in 4x4 mode, and the tractor is amazingly tough. There is no indication the pin is sheared, or just lost the cotter pin. I couldn't find the pin either time.
/ BX2200 front drive shaft pin sheared #18
Past year my neighbor asked for help with front differential drive shaft pinion causing the drive shaft to break when hauling hay for his cattle. 600/800 pound bales. on loader
lifting the front end noticed a plate with 2 bolts about meteric 3/8 american size one bolt had broke and was allowing the front axle bolt to move as much 1 inch forward and back .dependinfg on direction of travel. wear plate was dry of grease. Also the pinion and gears in front differential had to be replaced.along with the bearings on each side.seals included. required over $1ooo bucks in parts.
Just one expensive cost due to not greasing where book explains the need to keep the part greased.
2013 Komatsu PC360LC Hydraulic Excavator (A60352)
2013 Komatsu...
2022 Ford F-150 Pickup Truck, VIN # 1FTMF1CB1NKE47600 (A61165)
2022 Ford F-150...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61568)
2015 Chevrolet...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A60352)
2010 International...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
832789 (A61166)
832789 (A61166)
