BX22 Stuck in Turtle !!
   / BX22 Stuck in Turtle !! #21
It has to do with the fact that one is a BX series and the other is a B series, two complete different tractors. Also, the B series has a clutch pedal, no BX ever did.
Kubota changed their wiring and safety switches after the BX30 series. The BX24 and BX50 series and later models have a safety switch on the hydro linkage rather that the Range selector lever.
Attached is a list of BX series and years built.
Both the BX2230 and the B26TLB that JWR is quoting from are mine. Both are HST. The BX2230 has 2 ranges, while the B26TLB has 3 ranges. No clutches.
The backhoe has not been off the tractor in my ownership, other than when the mechanic showing me how when I picked it up in Feb 2018. Jon
   / BX22 Stuck in Turtle !! #22
I guess I should have stated that some of the B series had a clutch pedal, no BX series ever did. Some B series have a safety switch on the clutch pedal rather than on the hydro pedal or the Range lever.
   / BX22 Stuck in Turtle !! #23
I have an L model with 600+ hours and it was always difficult to shift between L/M/H. At about 400 hours it was in M and ever since I have been unable to shift to either L or H. I've screwed with the linkage, bumped it fwd and back while trying and directed harsh words at it. My solution was to discover that for the tasks I require, M works just fine! I don't know much about BX models but in my book, hard shifting is a "feature" of Kubota, at least the range selections on Hydro models.
   / BX22 Stuck in Turtle !! #24
My BX2200 has to be in N and the treadle needs to be in the middle for it to start. It gets me all the time to this day.
   / BX22 Stuck in Turtle !! #26
My BX2360 will start in either rabbit or turtle, always has.
   / BX22 Stuck in Turtle !! #27
All BX series after the BX30 series will start with the range lever in either Hi or Low.
Meyer 8.5' Snow Plow (A55272)
Meyer 8.5' Snow...
265 Gallon Tote Tank (A59225)
265 Gallon Tote...
48in Boom Lift Basket (A56857)
48in Boom Lift...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
