BX22 FWD
/ BX22 FWD #1
bobsedor
Binghamton, NY
Kubota BX22
I have a new BX22 (5 hours) and it is quite difficult to get it out of four wheel drive. Did others experience this now or when their tractor was new?
/ BX22 FWD #2
Mine is the same way. Try to rock the tractor forward and reverse just a little with foot pedal as you disengage the front wheels this should make it much easier. there should be nothing wrong with your tractor as most 4wd trucks are the same way, hard to disengage the 4wd at a stand still. see page 25 of your owners manual. it states "to avoid damage to the transmission,when front wheel drive lever is not smoothly shifted, slightly step forward or rearward on speed control pedal."
/ BX22 FWD
I saw that in the manual & that's how I get it out of FWD, but it just seems to take a lot of pressure.
Thanks for responding.
Bob
/ BX22 FWD #4
Mine does the same thing as well. If I hit the pedal a touch, it comes right out every time. I even find it will do this on the speed selection (fast/slow) as well; have to tap the pedal there too, especially if it's on an incline.
/ BX22 FWD #5
Bob,
You probably know this, but just in case, make sure you don't use 4WD in situations where you are getting good traction (like on pavement, etc.). If the tires can't "slip" a little, it is possible to load up the front gear box, which might be causing your trouble. It could also damage the gears. If you do happen to do this, just move the tractor to someplace where the tires can "slip" some, then try it again. My BX2200 is often difficult to get in and out of 4WD (more out than in). I usually let it roll some (in neutral), then try again. That usually does it.
Kevin
/ BX22 FWD
Thanks. Sounds like everyone is experiencing the same difficultly. I'll work the pedal and try the neutral "thing".
Bob
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2017 Ford F-250 Ext. Cab Pickup Truck (A61573)
2017 Ford F-250...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
John Deere 1770 Planter (A63111)
John Deere 1770...
