BX22 front differential case
/ BX22 front differential case #1
ragman
Green Garden,Illinois
BX22 TLB
The o rings are leaking on the front diff housing where it attaches to the frame. (the diff housing attaches by means of a single bolt thru the front frame) I've looked at the parts manual and found the bushings and o rings for the housing, but I have a question for someone who has a service manual. Is there a bushing that goes into the front frame where the bolt protrudes? (where the nut and cotter pin attach to the bolt end) The reason I ask is there seems to be a little play/slop in the frame hole where the bolt comes thru and the nut and cotter pin attach. I have the front diff removed and I can see what looks like a bushing, but I hesitate to go any further unless I know for sure. I'm going to order a shop manual on Monday from the dealer, but was just wondering if anyone had one and could look and see if it tells anything about a bushing.
/ BX22 front differential case #2
A cut and paste from a BX23 WSM on the front axle.
Looks like it makes mention of a bushing (called a bush).
Good luck
Thank you very much for the diagram. I can't wait to get my own copy of the WSM from the dealer.
SURE FIRE 5.3GPM LIQUID FERTILIZER UNIT TOWER (A64278)
SURE FIRE 5.3GPM...
John Deere 2840 Tractor (A64047)
John Deere 2840...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
213089 (A64276)
213089 (A64276)
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
