Bx1860 won't even click when I turn the key
   / Bx1860 won't even click when I turn the key #21
Could be a problem with the shut down solenoid,or the shut down timer.
  • Good Post
Reactions: JWR
   / Bx1860 won't even click when I turn the key #23
Just a further note: A lead-acid battery in a good state of charge should register 12.6v without the alternator charging it.
   / Bx1860 won't even click when I turn the key #24
Neither will cause a no crank situation.
Actually it IS possible for the fuel cutoff solenoid to disable cranking on some tractors like my BX2200, for example. The starter solenoid circuit is completed on the BX2200 through the Start coil of the fuel cut off solenoid. If that coil fails in the state where the winding wire opens, then the tractor will not crank.Obviously, if the fuel solenoid is unplugged at its electrical connector, the starter will also not crank.
Not sure about the OP's BX1860 though...
Case IH 330 Turbo Till (A59814)
Case IH 330 Turbo...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
2023 Kubota SVL 75-2 Skid Steer (A57453)
2023 Kubota SVL...
Kubota M5-111 (A53317)
