BX1860: Increasing FEL capacity? (by volume, not weight)
   / BX1860: Increasing FEL capacity? (by volume, not weight) #1
wrooster
Platinum Member
Looking for ideas here...
I've have a BX1860 for 3 years now and my only complaint is the volumetric capacity of the FEL. The sizing of the FEL is such that I can pick up and safely move a full load of 3/4" gravel, no problem (of course the little BX has to be appropriately ballasted at the rear...).
However, I am less often moving loose stone, and much more often moving fairly dry mulch and yard debris (sticks, leaves, etc). And for this reason, I would like some ideas on a bigger bucket for moving loose material such as mulch. Now, you are thinking, "what a PITA, changing the bucket to move one sort of material...". But, if you have ever moved 20 cubic yards of mulch with a BX (0.20 cubic yard capacity bucket) you would know what the problem is here.
Products: LA203 Kubota Canada Ltd.
Standard
Capacity - struck 4.2 cu. ft. (0.120 mウ)
Capacity - heaped 4.9 cu. ft. (0.140 mウ)
I know that BXpanded makes a "bucket extender" but are there other options I should be looking at? I really need a fairly lightweight, 60" wide, deep, "loose material handling" bucket suitable for a few hundred pounds of mulch. I promise not to pick up 500 pounds of 3/4" stone with it.
What say you folks?
Wrooster
Bruce,
Thanks for the link. That project seems set up for light brush. I'm thinking I need something smaller than that, and bigger than the OEM FEL.
Wrooster
   / BX1860: Increasing FEL capacity? (by volume, not weight) #4
Wrooster,
I built this thing out of some scrap plywood to expand the capacity of the bucket on my B3030. It's great for light duty stuff, like leaves and firewood.
   / BX1860: Increasing FEL capacity? (by volume, not weight) #5
Well- what do you want it made with ? steel or wood? With wood - you can built it and see if it works for you. If it doesnt, you always can hack it and rebuild it as needed. With steel - you are limited to with what cost and what you have on hand.
   / BX1860: Increasing FEL capacity? (by volume, not weight) #6
See if you can find a bucket for a B size tractors and have or DIY put some pins to match you tractor.
   / BX1860: Increasing FEL capacity? (by volume, not weight) #7
Wrooster,
Bxpanded just announced the bucket extender for the 1860, go to the website you will be all set,
CAS300D
Wrooster,
CAS300D
I love this place. :)
I hate this place. :laughing:
Wrooster
2005 Ford F-150 Pickup Truck (A48081)
2005 Ford F-150...
Hand Tedder (A49251)
6000LB Axle (pair) (A49251)
6000LB Axle (pair)...
T-POST & WIRE (A48992)
2012 TROXELL 130BBL (A48992)
2012 TROXELL...
More info coming soon! (A48082)
More info coming...
