BX1860: Increasing FEL capacity? (by volume, not weight)
   / BX1860: Increasing FEL capacity? (by volume, not weight) #1
wrooster
Looking for ideas here...
I've have a BX1860 for 3 years now and my only complaint is the volumetric capacity of the FEL. The sizing of the FEL is such that I can pick up and safely move a full load of 3/4" gravel, no problem (of course the little BX has to be appropriately ballasted at the rear...).
However, I am less often moving loose stone, and much more often moving fairly dry mulch and yard debris (sticks, leaves, etc). And for this reason, I would like some ideas on a bigger bucket for moving loose material such as mulch. Now, you are thinking, "what a PITA, changing the bucket to move one sort of material...". But, if you have ever moved 20 cubic yards of mulch with a BX (0.20 cubic yard capacity bucket) you would know what the problem is here.
Products: LA203 Kubota Canada Ltd.
Standard
Capacity - struck 4.2 cu. ft. (0.120 mウ)
Capacity - heaped 4.9 cu. ft. (0.140 mウ)
I know that BXpanded makes a "bucket extender" but are there other options I should be looking at? I really need a fairly lightweight, 60" wide, deep, "loose material handling" bucket suitable for a few hundred pounds of mulch. I promise not to pick up 500 pounds of 3/4" stone with it.
What say you folks?
Wrooster
Bruce,
Thanks for the link. That project seems set up for light brush. I'm thinking I need something smaller than that, and bigger than the OEM FEL.
Wrooster
   / BX1860: Increasing FEL capacity? (by volume, not weight) #4
Wrooster,
I built this thing out of some scrap plywood to expand the capacity of the bucket on my B3030. It's great for light duty stuff, like leaves and firewood.
   / BX1860: Increasing FEL capacity? (by volume, not weight) #5
Well- what do you want it made with ? steel or wood? With wood - you can built it and see if it works for you. If it doesnt, you always can hack it and rebuild it as needed. With steel - you are limited to with what cost and what you have on hand.
   / BX1860: Increasing FEL capacity? (by volume, not weight) #6
See if you can find a bucket for a B size tractors and have or DIY put some pins to match you tractor.
   / BX1860: Increasing FEL capacity? (by volume, not weight) #7
Wrooster,
Bxpanded just announced the bucket extender for the 1860, go to the website you will be all set,
CAS300D
Wrooster,
CAS300D
I love this place. :)
I hate this place. :laughing:
Wrooster
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
377870 (A48836)
377870 (A48836)
14FT HORIZONTAL SPOOL TRAILER (A48992)
14FT HORIZONTAL...
2002 KENWORTH T600(INOPERABLE) (A48992)
2002 KENWORTH...
2017 Case IH 4412F (A47164)
2017 Case IH 4412F...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A45679)
2017 KENWORTH T680...
