BX1850 Block heater
   / BX1850 Block heater #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Has anyone installed one of the factory block heater kits on their BX18**. I purchased one of these kits and the pictures are black and impossible to identify any components. Was hoping someone could possibly post a couple of pictures showing how this unit is mounted and plumbed. If not I will proceed in the usual farmer fix method and make it work.
TIA
Roy
   / BX1850 Block heater #2
Use the search for BX block heater and you will see a post from Charlebrn. Thats what I used for mine. It was very well done. I made copy of it and used it again when helping a friend install one. Good luck.
thanks,
problem is the BX1850 uses a different system than the BX23**
1998 PRATT ISO DROP FRAME TRAILER (A59575)
1998 PRATT ISO...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
We Don't Call 911 Metal Sign (A57454)
We Don't Call 911...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2021 Ford F-150 Pickup Truck, VIN # 1FTEW1EP2MFC48947 (A57453)
2021 Ford F-150...
Ford 8510 (A53317)
Ford 8510 (A53317)
