BX1850 Block heater
/ BX1850 Block heater #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Has anyone installed one of the factory block heater kits on their BX18**. I purchased one of these kits and the pictures are black and impossible to identify any components. Was hoping someone could possibly post a couple of pictures showing how this unit is mounted and plumbed. If not I will proceed in the usual farmer fix method and make it work.
TIA
Roy
/ BX1850 Block heater #2
Use the search for BX block heater and you will see a post from Charlebrn. Thats what I used for mine. It was very well done. I made copy of it and used it again when helping a friend install one. Good luck.
thanks,
problem is the BX1850 uses a different system than the BX23**
