BX1500 Question
/ BX1500 Question #4
The 54" deck is great. No power issues whatsoever. The only time it's ever lugged down was when I cut my neighbor's 14" tall, very thick, wet grass - obviously more than it was intended for. Even then, all I had to do was slow down a bit. The 54" deck (at least when I bought mine) has a steel chute deflector and pulley covers. They were plastic on the 48" model. I perceive steel to be better quality.
/ BX1500 Question #5
I have had my bx 1500 for 3 years and have never had the 54" deck bog down. I also use it in the fall to help with leaf removal, since I don't have a sweeper, etc. I just start next to the trees with the deck up and then make circles, until I have the leaves in a pile, it mulches/blows the leaves into a pile and as the leaves pile up the mower keeps cutting /blowing them with no bogging down.I then load up the leaves in a cart and the loader and haul them away into the fields and dump/spread them out. Sure beats raking them all. I only use a rake to pick up the leaves to put them in the cart and loader bucket.
/ BX1500 Question #6
How fast do you go?? Mine seems to run fine, but the 54 deck will bog it in average to thick grass unless I mow in low range, or significantly back off in hi range. Even in low range it will not mow uphill at full pedal speed.
larry
/ BX1500 Question #7
SPYDERLK said:
How fast do you go?? Mine seems to run fine, but the 54 deck will bog it in average to thick grass unless I mow in low range, or significantly back off in hi range. Even in low range it will not mow uphill at full pedal.
larry
I used to have a 1500 and it performed well. Are you running full throttle??? I can see bogging on a serious hill but not on a normal lawn, especially in low range where the thing is a tank.
/ BX1500 Question #8
Mine will not cut uphill/thick grass at top speed even in low range. I don't have a problem with that since I don't need to go top speed anyway. My lumpy lawn would beat me to death if I went too fast. I would get the 54 again, it works for me.
/ BX1500 Question #9
Did you have a 54" mower? I run full throttle to mow and it will mow anything if you go slow -- even 2" trees. However, I always have to go below full speed in low range for thick grass even if its not very high.
larry
/ BX1500 Question #10
larry
Yep, a 54" mower. I would have to slow a bit if the grass was heavy and over 6" tall but always mowed in high range about half pedal.
/ BX1500 Question
I have a BX1500 on order with the 48'' mmm.
I really wanted a 54'' mower because the CC that the BX Is replacing has a 54'' mower deck which I really like.
I'd heard that the 54'' mmm was to much mower for the BX1500 and causes it to lug down while mowing so I resigned myself to the 48'' mmm.
Now I'm having second thoughts about the 48'' mmm and am wondering if I should switch the order to a 54'' mmm.
:confused: Guys I need your help deciding.
Should I switch to the 54'' or just stick with the 48''? :confused:
Thanks everyone for all of your replys.
/ BX1500 Question #13
LBrown59 said:
Who all has a hydraulic lift and angle front blade on their BX1500 ?
I dont. Im really disappointed in the kluge they came out with for aux hydraulics. When I bought the tractor and saw the designated slot on the fender I just knew they had an integrated accessory system up and coming. NOPE
larry
/ BX1500 Question
Thanks all for your responses about the 54'' mower question.
I would still very much like to hear from everybody who has a BX1500 with a hydraulic lift and angle front blade on their BX1500!
I've had a little bit of a problem in getting one for the BX1500.
Seems Kubota don't make the 54'' blade that's for the BX1500 with the hydraulic angle option.
So what I and the dealer decided to do is order the BX2230 / B23 60'' hydraulic lift and angle front blade.
* Would love to hear about the experiences of all of the BX1500 front blade owners.
/ BX1500 Question #15
I have the 54"mm and love it. It has never bogged down or skipped a beet for me. I have even cut tall wet grass in my pasture and it never even hiccupped. If it were me I would get the 54"?
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
250 Gallon John Deere Sprayer (A65579)
250 Gallon John...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
NEW 14' RS GODWIN BODY (A62613)
NEW 14' RS GODWIN...
New/Unused Electric Winch (A65583)
New/Unused...
