BX SUPER LEAF CHOPPER
/ BX SUPER LEAF CHOPPER #1
WALT
LOUDON NH
KUBOTA BX2200, L-39 TLB & RTV X1100C
Perhaps I am telling you something that you already know, but I just finished chopping leaves at my folks 1 acre lawn, and continue to be impressed at the capabilities of this machine. The leafs in CT. are finally dropping, and are mostly oak and maple.
If you are blowing leafs instead of chopping them, you may want to give it a try. More seat time is never a bad thing.
First: You need to have a tree line or woods to blow them into, but if you pick them up, the remains will be much less than if you blew them.
Second: The leafs must be dry for good chopping action.
Third: It takes more time, but you must cut in only one direction. After starting, cutting in a lazy "C" method gives you the best chopping/ moving results. The first half of the lawn area, the leafs will pile over the mower deck. To deal with that, take a pass with the mower raised, then lowered. I use the 2" setting. Also, occasionally make random cuts through the pile, to spread out the discharge. By the final third of the lawn, the discharge is a fine mulch that continues to be easily dispersed. You do still need to rake around trees, house, etc. A side benefit is that the chopped leafs don't blow around, if you don't get a chance to pick them up right away. Be sure to keep the radiator grille screen clear.
Prior to owning the BX2200, I used to use my dad's 1969 Cub Cadet 125. It is now retired, as it would usually need $50.00-$100.00 worth of parts to complete the job. Diesel, 4WD and Shaft Drive, beats gasoline, spinning tires and belt drive any day.
Time was also reduced from 2 days to 3 hours, due to the lack of mower belt breaks and constant clogs.
If anyone could appreciate my story, I figured it might be you folks.
Happy Chopping:
WALT
/ BX SUPER LEAF CHOPPER #2
I also chop leaves with my BX. I don't have a tree line or woods to blow towards so I start from the outside of the circle and blow inwards. I just keep going around an area until I have reached the middle, then I make a couple more passes up and down the center until I have very small bits of leaves left. Works pretty good that way. Beats the heck out of raking. If I did have some woods around my yard I would probably try it your way. It also helps if you mow them every few days while they are falling. Don't wait until the trees are bare. Happy chopping.
/ BX SUPER LEAF CHOPPER #3
I use my grass catcher to pickup the leaves on my b7500, it works great.
nhman
/ BX SUPER LEAF CHOPPER #4
I chop them up also, but I leave them on the lawn. I have to chop a few times and push them around a few more times,.. but eventually the filter through the grass. I figure that makes them cheap fertilizer!
The stuff that blows up to the fence line and doesn't sink in to the grass, I get with a gentle scrape of the loader after it has melted in to a big line of grass clump. It scrapes right in to the bucket and gets tossed over the hill.
Sakai SW354 (A60462)
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
Ford 8210 (A60462)
Ford 8210 (A60462)
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2004 John Deere 310SG 4x4 Extendahoe Loader Backhoe (A61572)
2004 John Deere...
