BX Steering issue
/ BX Steering issue #21
Update: I got the clip off and drove the end seal loose. The seal will move about 1/4" since removing the retainer but won't come out. The opposite end is even with the cylinder. Does it need to be driven out further? I tried but didn't want to go overboard.
/ BX Steering issue #22
Yay! ... I may have used air pressure to get it fully out. There is some danger due release of compressed air energy when it comes out, so i dont recommend it. Cant you drive the rod further with a soft punch acting on the bottom of the threaded hole of the rod? ... -- ... You may want to tap the endseal back in and make sure you created no burrs removing the clip before you force the endseal/guide on out.
2018 HINO SA (A58214)
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
Unused 2025 CFG Industrial H12R Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3015 (A56857)
3015 (A56857)
