BX Steering issue
/ BX Steering issue #21
Update: I got the clip off and drove the end seal loose. The seal will move about 1/4" since removing the retainer but won't come out. The opposite end is even with the cylinder. Does it need to be driven out further? I tried but didn't want to go overboard.
/ BX Steering issue #22
Yay! ... I may have used air pressure to get it fully out. There is some danger due release of compressed air energy when it comes out, so i dont recommend it. Cant you drive the rod further with a soft punch acting on the bottom of the threaded hole of the rod? ... -- ... You may want to tap the endseal back in and make sure you created no burrs removing the clip before you force the endseal/guide on out.
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
2025 Auger Drill Bit Skid Steer Attachment (A61572)
2025 Auger Drill...
UNUSED WOLVERINE RPR-12-72W-72" RIPPER (A64281)
UNUSED WOLVERINE...
2010 Case 580N (A60462)
2010 Case 580N...
