BX snow chains source
/ BX snow chains source #1
allthumbs23
WI
Kubota BX2230
I have a BX 2230 with turf tires and am spinning alot on my gravel drive with the wet snow using the front bucket. Anyone have a source for tire chains? Thanks
/ BX snow chains source #2
tirechains.com tirechainsrequired.com Search button works well. :thumbsup:
/ BX snow chains source #3
May want to consider some type of rear weight even w/tire chains.
/ BX snow chains source #4
I've got the same tractor and tires. I have my rear tires full of washer fluid and I hang either a 275lb weight bar or 200 lb 5 foot rear blade on the back end. On my paved driveway, I have pushed snow hard enough to lift the front end off the ground and then had the rear tires squawk. Chains may help, but get weighted down first.
/ BX snow chains source #5
I did tirechains.com as well and it makes a huge difference
/ BX snow chains source #6
Try the local walmart or auto parts store . A set for a car could work .
You know what else would help? If I had put the **** thing in 4WD!! I was in such a hurry today to get the wife going I spaced on it. That's embarrassing....
/ BX snow chains source #8
you might check on e-bay also. think jd 1025r(not sure model #) uses same tire size as bx-series. I got mine for under $25/set front&back off season on e-bay even got a second set for rears but have not needed double chain in 4 wheel drive
/ BX snow chains source #9
We won't tell the wifey what you did! It happens to the best of us.
/ BX snow chains source #11
I used a old set of truck tire chains from 15 inch rims , minor modifications and has worked fine for 5 years now.
/ BX snow chains source #12
In this part of the world there is a tire dealer - Les Schwab - that can order chains for a tractor. I got heavy duty tractor chains when I had my Ford 1700. I got a funny feeling when it took two BIG guys to carry the box of chains(for all four wheels) out and load them into the pickup. The rear V-bar chains were right at my limit of lifting ability. I would not even consider the purchase price or seasonal installation of a set like that for my new tractor.
/ BX snow chains source #15
I'm partial to tirechains.com myself. After a lot of shopping that is where I got mine.
George
/ BX snow chains source #16
George
/ BX snow chains source #17
got mine from there a few years ago and they help a lot. I did the 2 link chains and i also ordered some 'tighteners' to keep the flapping to a minimum
be prepared to have to remove some links etc to get them fitted correctly, so allow several hours the first time you put them on.
I found that if i jack up the tractor and using a bungee cord on the one end of the chain, spin the tire and it will pull the chain up onto the tire.. Then I hooked them at the loosest point.. spin the tire and grap another link.. spin the tire, and keep tightening until they were as tight as i could get them.. then I zipped tied the loose ends and put on the stretches..
brian
/ BX snow chains source #18
Mine fit great, I also got the tensioner so and recommend that, a bungy works too. You may want to check clearances. I had to get spacers on a b to fit chains.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
iDrive TDS-2010H...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
84'' SKID STEER BUCKET (A61572)
84'' SKID STEER...
