BX snow chains source
/ BX snow chains source #1
allthumbs23
WI
Kubota BX2230
I have a BX 2230 with turf tires and am spinning alot on my gravel drive with the wet snow using the front bucket. Anyone have a source for tire chains? Thanks
/ BX snow chains source #2
tirechains.com tirechainsrequired.com Search button works well. :thumbsup:
/ BX snow chains source #3
May want to consider some type of rear weight even w/tire chains.
/ BX snow chains source #4
I've got the same tractor and tires. I have my rear tires full of washer fluid and I hang either a 275lb weight bar or 200 lb 5 foot rear blade on the back end. On my paved driveway, I have pushed snow hard enough to lift the front end off the ground and then had the rear tires squawk. Chains may help, but get weighted down first.
/ BX snow chains source #5
I did tirechains.com as well and it makes a huge difference
/ BX snow chains source #6
Try the local walmart or auto parts store . A set for a car could work .
You know what else would help? If I had put the **** thing in 4WD!! I was in such a hurry today to get the wife going I spaced on it. That's embarrassing....
/ BX snow chains source #8
you might check on e-bay also. think jd 1025r(not sure model #) uses same tire size as bx-series. I got mine for under $25/set front&back off season on e-bay even got a second set for rears but have not needed double chain in 4 wheel drive
/ BX snow chains source #9
We won't tell the wifey what you did! It happens to the best of us.
/ BX snow chains source #11
I used a old set of truck tire chains from 15 inch rims , minor modifications and has worked fine for 5 years now.
/ BX snow chains source #12
In this part of the world there is a tire dealer - Les Schwab - that can order chains for a tractor. I got heavy duty tractor chains when I had my Ford 1700. I got a funny feeling when it took two BIG guys to carry the box of chains(for all four wheels) out and load them into the pickup. The rear V-bar chains were right at my limit of lifting ability. I would not even consider the purchase price or seasonal installation of a set like that for my new tractor.
/ BX snow chains source #15
I'm partial to tirechains.com myself. After a lot of shopping that is where I got mine.
George
/ BX snow chains source #16
George
/ BX snow chains source #17
got mine from there a few years ago and they help a lot. I did the 2 link chains and i also ordered some 'tighteners' to keep the flapping to a minimum
be prepared to have to remove some links etc to get them fitted correctly, so allow several hours the first time you put them on.
I found that if i jack up the tractor and using a bungee cord on the one end of the chain, spin the tire and it will pull the chain up onto the tire.. Then I hooked them at the loosest point.. spin the tire and grap another link.. spin the tire, and keep tightening until they were as tight as i could get them.. then I zipped tied the loose ends and put on the stretches..
brian
/ BX snow chains source #18
Mine fit great, I also got the tensioner so and recommend that, a bungy works too. You may want to check clearances. I had to get spacers on a b to fit chains.
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
2007 Blue Bird All American Bus (A61573)
2007 Blue Bird All...
HARDEE 4R SPRAYER (A63291)
HARDEE 4R SPRAYER...
2017 Dodge Journey SUV (A61574)
2017 Dodge Journey...
2005 John Deere 7320 (A60462)
2005 John Deere...
