BX Seat Safety Switch
   / BX Seat Safety Switch #1
jesseb3@att.net
South Central PA
Kubota BX2350, John Deere X530
I saw another post regarding the seat safety switch being a PITA on the BX series, and thought I'd share my method of fixing it.
My tractor used to sputter frequently while running over bumpy ground, or when backing up, as my weight would shift forward off of the seat. I'm only 145 lb on a good day. :eek:
Anyway, the metal arm that pushes down on the safety switch is "doubled", i.e. there are two similar if not identical plates bolted together. They're made of steel, and are chemically treated (not galvanized) to a goldish appearance. These are supposed to provide some travel so that the switch remains activated even as it springs up and down a bit.
By removing one just one of them, the seat switch works flawlessly for both myself and my wife. This allows it to work as intended, while solving all of the stalling issues.
I apologize for my somewhat cryptic description of the part, but I did this mod two/three years ago, shortly after I got the tractor.
Jesse
   / BX Seat Safety Switch #2
Thanks for the heads up...if mine starts acting up or if the wife decides to drive more, then I may have to start looking into that.
   / BX Seat Safety Switch #3
Can you post pictures?
   / BX Seat Safety Switch #4
Thanks Jesse. I'll try it. I'm lightweight too and have the same problem with engine stutter as I bounce over a bump. It is irritating to the point I want to disconnect the switch all together. Maybe your fix will help (and adjust my attitude as well).
   / BX Seat Safety Switch #5
This was another irritation with the BX2350 I had before trading it to a BX2660. I'm over 200 lbs and have hillside property and going down hill I would have to pay alot of attention to lean back all the time. When my wife drove it it sputtered all over the yard. My BX2200, BX1500 and BX2660 do/did not have this problem. Glad to see an easy fix.
Pictures this time...
Again, the lever was doubled-up - one right on top of the other, and only connected by the two mounting bolts.
I wonder if the Kubota folk used multiple lever/springs as a means of calibration? Though that doesn't make sense either, as that would imply that only one lever, with a heavy operator, would result in a different problem. Otherwise, they'd only use one lever for everyone(?)
Jesse
   / BX Seat Safety Switch #7
I removed mine about a year ago. Haven't had any problems except on really uneven ground. Removing one of the plates is a easy fix.
   / BX Seat Safety Switch #9
I did the same mod to my 2350 a couple of years ago. The engine now runs and kills when I think it should.
   / BX Seat Safety Switch #10
I have a BX2350, I'll have to try it. I'm a big guy and I still have problems with it killing now and then. Thanks for the pics, that really helped.
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
