BX Owners -- ANOTHER Front End Question
/ BX Owners -- ANOTHER Front End Question #1
Rimmer
Lower Ohio River Valley
Kubota BX23, Ford 8N
BX Owners -- how much side-to-side play do you have in your steering cylinder? Not in the tie rods, etc, but in the main rod that comes out of the cylinder itself?
I have noticed that mine has maybe 0.010" to 0.015" of play in it -- enough that I can actually feel it "clunk" when I shake the tractor from side to side with the FEL off the ground, or when I wiggle the front wheels, for that matter. You can actually see the seals moving with the rod. I called my dealer yesterday to ask if this was normal, and he came out today to look at it. He said he would check with a Kubota tech and see what the specs are, and if needed would install shim washers to take up the slack, or replace the whole cylinder if necessary.
BX23, 29.9 hours.
/forums/images/graemlins/tongue.gif
/ BX Owners -- ANOTHER Front End Question #2
Mine has a little more than 1/8 of an inch, It's almost like it's not "tight" in the mount, but there's no way to remove the play.
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
PALLET OF (3) CONCAVES OF CASE 2388 (A64281)
PALLET OF (3)...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2020 Deere 544L (A60462)
2020 Deere 544L...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
