BX mower blade question
/ BX mower blade question #1
Tomtint
Elite Member
Boston
L3700SU
So my father removed his blades and got them sharpened over the winter. I can not remember and he did not write down the stacking order of the washers and lock washer. Does anyone know weather a compression washer goes under and over the blade or is the blade placed over the spline then 2 washers and the lock washer then the bolt?
/ BX mower blade question #2
The blade, then two cupped washers, then the locking washer, then the bolt. Tighten it well or the blades will slip in heavy cutting.
/ BX mower blade question #3
I tighten mine to 80 foot pounds, as mentioned if you don't get them tight enough they will slip too easily.
/ BX mower blade question #4
pdowling1 has it right.:thumbsup:
Thanks for he help.
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2016 Freightliner M2 106 Ambulance (A64556)
2016 Freightliner...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2008 Honda Civic Coupe (A64557)
2008 Honda Civic...
2018 RAM 2500 (A65643)
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
