BX mower blade question
/ BX mower blade question #1
Tomtint
Elite Member
Boston
L3700SU
So my father removed his blades and got them sharpened over the winter. I can not remember and he did not write down the stacking order of the washers and lock washer. Does anyone know weather a compression washer goes under and over the blade or is the blade placed over the spline then 2 washers and the lock washer then the bolt?
/ BX mower blade question #2
The blade, then two cupped washers, then the locking washer, then the bolt. Tighten it well or the blades will slip in heavy cutting.
/ BX mower blade question #3
I tighten mine to 80 foot pounds, as mentioned if you don't get them tight enough they will slip too easily.
/ BX mower blade question #4
pdowling1 has it right.:thumbsup:
Thanks for he help.
Grey Fox Portable Creep Feeder (A66408)
Grey Fox Portable...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
