Henro
Super Member
- Joined
- Jul 4, 2003
- Messages
- 5,008
- Location
- Few miles north of Pgh, PA
- Tractor
- Kubota B2910, BX2200, KX41-2V mini EX
When I was researching my first tractor purchase early last summer I was kind of put off by the BX spec of something like 6.5 inches for ground clearance. As a matter of fact...that may be one important reason I ended up with a B2910.
This afternoon I was in the shed and looked at my bx2200 [which I bought this Summer as a little sister to my B2910] sitting there without the MMM...sure looks like a lot more than six inches under there I thought.
A quick measurement with the tape measure showed about 12 inches below the frame. Now the linkage from which the MMM hangs [MMM is not on the tractor at the moment] is about 6.5 inches above the ground. But the frame is much higher...and if there was no MMM that linkage would not be there...
A measurement of the rear transmission housing showed it to be about 7 inches above the shed floor. But my B2910 which has a published ground clearance of about something like 14+ inches has about 12 inches under the rear housing...
I guess what I am trying to say is that it looks to me like the published 6.7 [just checked the Kubota site] inches of ground clearance for the BX Kubotas is kind of misleading...Even though it may be technically correct...but then my B2910 must be wrong...I certainly do not have 14.7 inches under my rear housing...
Is there a specification for how ground clearance is measured? I'm sure there is...and also sure that not everyone follows it. But it sure seems like 6.7 inches does misrepresent the reality of the BX series...
Anyone have any comments?
