BX differences 2360/2370
/ BX differences 2360/2370 #1
KENSFM
MA
JD 2210 JD318 JD332
What are some of the differences between a Kubota BX2360 and a BX2370. I know the BX2370 is the newer model, but my dealer has a few of the
BX2360 models in stock and said he will give me a "great" deal on one.
Thanks, Ken
/ BX differences 2360/2370 #2
Let's see, from memory: Newer, better seat; new steering wheel; new dash with dedicated tachometer; option for quick attach FEL, pallet forks and snow blade (but can be put on older models though not officially recommended by Kubota); and I think some tweaks to the hydraulics, but that could be exclusive to the backhoe models. Can't think of anything else, but I'm sure if there are more, someone will pop in with additions.
Edit - just remembered they added options for a toolbox and fender mounted LED lights like the new JD1026/1025, and some other lighting options. But again, I'm pretty sure all of them can be retro fitted to the BX2360. You could even change the seat and steering wheel to the 70 series if you wanted, so the dash layout might be the only thing you couldn't put on a BX2360 (or at least easily).
/ BX differences 2360/2370 #3
Left side brake pedal.
The whole gauge cluster is different.
Arrow Quip EF10 Top Bow No Sides (A64047)
Arrow Quip EF10...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2018 John Deere R4045 Spayer (A63109)
2018 John Deere...
