BX 54" vs 60" MMM
/ BX 54" vs 60" MMM #1
kyoders
Western NC
Kubota BX2200
BX 54\" vs 60\" MMM
Does anyone have an opinion (what a question) on whether there is much difference between the two as far as being able to get in close to mow around obstructions? The issue isn't will it fit between things (like the house and a tree), but is it any easier to mow around a tree with one or the other? In my case, there isn't much of a difference in price, and it seems the extra width should help in open areas. But I'm concerned about trimming around things. Unfortunately, getting the dealer to let me give it a try isn't an option (he has no 54" decks and rarely ever sells them). Any comments would be greatly appreciated.
Kevin
/ BX 54" vs 60" MMM #2
Re: BX 54\" vs 60\" MMM
Kevin; I have the 60" deck. I tested a tractor with the 54', and I think the 60 enables you to get closer to obstacles and make a tighter turn. Also, remember the 60 is quite a bit heavier and features the side-to-side anti-scalp adjustment on the back of the deck (I can't remember what Kubota actually calls it. /forums/images/graemlins/blush.gif) I think the 60" is the way to go unles you have access problems to parts of your property.
Will
/ BX 54" vs 60" MMM #3
I have the 54" because of restrictions that I have on my property, but without that problem I would suggest the 60".
/ BX 54" vs 60" MMM #4
I have the 60" and have to cut around alot of trees and flower beds. I can get closer with it than the 54" The 54" will cut just the width of the tires, which wouldnt work for me as I cut under a long stretch of bobwire. The 60" allows me to cut under it without getting my tires in it. My .02
/ BX 54" vs 60" MMM #5
Go with the 60". I had a 1860 Kubota with a 54" deck. When I moved up to my BX I got the 60". It only took me a couple of hours to get used to it. Now theres no way I would want to go back to the 54". I think that I can trim just as close with 60" as I did with the 54".
/ BX 54" vs 60" MMM #6
Do not get the 54, the 60 is a better deck and will trim much closer. It is a fact, it has a smaller uncut radius and the edge sticks out further to trim around trees and beds. The only reason the get a 54 is it is narrow and may fit between gates better etc. It is also lighter to move around. (I am going for the 250,000 prize!) J
/ BX 54" vs 60" MMM #7
<font color="blue"> side-to-side anti-scalp adjustment on the back of the deck (I can't remember what Kubota actually calls it. ) </font>
I think the Kubota feature that Will_C is referring to is "Self-Balancing". The 60" deck has Self-Balancing and the 54 inch does not. I bought the 60 inch deck for all of the reasons mentioned by Will_C. I bought my BX2200 in December so I haven't used my mmm yet. I am beginning to think that I may never get a chance to use it!/forums/images/graemlins/grin.gif It was 3 degrees here yesterday... No signs of Spring, not even any robins?
Can't wait to do some serious work with the Bota; lots of projects planned... come on Spring!
John
/ BX 54" vs 60" MMM #8
I've got a 60" on my 2200 and love it. made one slight mod, put a rope on the deflector so I can trim with both sides of the deck. I have gone and cut my old hay fields and not had any problems. good heavy deck. /forums/images/graemlins/smile.gif
/ BX 54" vs 60" MMM #9
I have the 60 as well. It's awesome. It is very easy to mow around obstacles with and cuts VERY well.
/ BX 54" vs 60" MMM
Thanks everyone. I was leaning towards 60", just wasn't sure if there was any downside. Sounds like as long as it will physically fit between everything you need it to, there's no reason to go with the 54" over the 60".
Kevin
/ BX 54" vs 60" MMM #12
Just to add one lone voice from a different POV. I bought the 54" MMM. My decision was based on my particular mowing needs and budget. It has the same float feature as the 60", but lacks the self balancing mech because the smaller size does not require it. Otherwise, it's the same great mower at the 60"
/ BX 54" vs 60" MMM #13
I have the 60" MMM and I have to tell you, that I have to do almost NO trimming after I'm done other than just a few spots that I can't fit the deck into! (I do cut around a lot of trees, too)
/ BX 54" vs 60" MMM #14
I have a 54" on my BX2200. The narrower width fits between trees in my yard and also takes up less room in my already full garage. Also I only mow about 1.5 acres with my MMM. If I had a lot more to do I may have opted for the 60" but in my situation the 54" actually works better.....
/ BX 54" vs 60" MMM #15
I have the 60" mower, I like the way it sticks further out to the sides. I can trim right over the edge of the border between grass & the bark mulch. Saves a lot of time, I don't have to go all arounnd with the string trimmer. I can cut at pretty much full speed because all 4 wheels are on the grass I don't have to worry about running over the mulch just to get a close cut.
/ BX 54" vs 60" MMM #16
I have a 54" mower with Mulch kit installed. I do not have much grass at all to mow, however I wish I had gone for the 60". The cut of the 54" is just as good as the 60", but I cannot get as close in to flower beds and trees as I could with a 60". There are a couple areas of the yard that I have to do with a Weed Eater (Shame to use "manual labor" when the tractor is nearby).
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2023 Caterpillar...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
