LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,831
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
YA Think !It could have something to do with the title of this thread?
The question could be objectively evaluated with an infrared camera. But I just ain't that curious. I *want* air flowing through the entire engine compartment.
After hard mowing I idle down for 5 minutes, then open the hood after shut down. Lets heat out and reminds me to check the oil next time I start up.
If BX's have a heat management issue, it is the hydraulics. No oil cooler. The hydro consistently runs 90-100 degrees (F) above ambient. Attached image is after trenching (BH) on a 90 degree day.
I agree with the thought that an external cooling coil (see the Surplus link) placed on the return line to the tank would go a long way to helping things out.
For about $120 bucks (for the unit, hoses, some 12v computer fans and some couplers), I plan on building one of these at some point to help out this problem. I am not sure how much it will help, but I have burned myself leaning against a ram by accident after heavy use.
The BX2350 suffers from the same problem, mowing hard on a hot day the engine will run +15 to +20 degrees higher than it will on a cool day, verified with an infrared thermometer aimed at thermostat housing. Running with the hood open or by removing the skirt around the engine will lower the engine temperature pretty much back to normal. I'm sorry guys, but a properly designed cooling system (including air circulation) for any engine should not allow the engine temperature to vary that much above the normal operating temperature. The only reason I can see for running with the hood closed is that you lose the pre-filtering of the intake air thru the battery compartment. Myself, I prefer to run without the skirt.
As a test, take your hand and feel the air flow coming out of the vents on the sides, front and bottom of the skirt, then remove the skirt and feel the air flow the fan is actually generating, I know its not very scientific, but it feels like a significant difference. Looks to me that there is a lot of restriction to air flow past the alternator, air filter, fuel injection pump, thermostat/radiator hose when the skirt is on. I am actually considering cutting vents toward the back of the skirt, and maybe the hood, if I can come up with a way of doing it that looks nice, otherwise I'll run without the skirt until the temps cool down.
If you wear long sleeves and gloves you won't burn yourself on the hot cylinder
Otherwise, the hydraulics needs a cooler. Opening the hood may not help that much. Those few pics of hydraulics coolers above would be a good idea, but not so good for the winter (if it gets cold by you). Think of an electric fan that you can disable in the winter and a way to keep air from passing over the cooler. Otherwise a cooler on the return side is probably your best bet. The bigger the better too . . .
When I get around to building one, I plan to simply "quick hydraulic coupler" the cooler on the return circuit by the BH
