BX 22 Coolant Leak
/ BX 22 Coolant Leak #1
DOC4444
Massachusetts
Kubota BX22
BX 22 is spitting out coolant below the water pump and on top of a round housing that bolts to the block below the water pump housing. (Unfortunately, it is not coming from the water pump shaft seal. That would not be too bad to get to.) For some reason, despite all the manuals that came with it, we don't seem to have a picture of the water pump end of the motor. The round housing has some vents in it, sort of like the back of an alternator, but it does not have a pulley attached to it. (The coolant is not coming out of the vents, but rather over the top of the housing.)
Anyone able to direct me to a picture of the front of the motor and/or have any bright ideas? (Its also not the bottom coolant hose. It's just really tight in there and I can't get a look.)
I'd like to be able to have the repair parts on hand before taking it all apart. (We are getting lots of snow these days and I can keep using it by adding coolant. We'll be snowbound if it is out of commission for several days.)
Thanks,
DOC
/ BX 22 Coolant Leak #2
Most every water pump I have ever seen, has a weep hole in the bottom of the casting, between the seal and bearing assembly. When the seal goes bad, the water comes out the bottom, not out of the end of the shaft. Look carefully and see if the coolant is dripping out of the underside of the pump.
/ BX 22 Coolant Leak #4
Yep...in the auto world, that's a classic bad water pump...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2025 JMR 40in Hydraulic Single Cylinder Brush Grapple Mini Skid Steer Attachment (A59228)
2025 JMR 40in...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
