BX 18 Power
/ BX 18 Power #1
Slab
Ny
Yanmar sc2400
I have cub cadet 25 horse garden tractor GT3235 with 54 in deck and 45 in front mount blower that meets my needs well. I'm thinking about getting a BX 18 with loader,deck and rear blower. My concern is with the power of an 18 horse diesel compared to a 25 horse gas. Will it be under powered?
/ BX 18 Power #3
I agree. My 1860 does everything I ask of it with ease. You'll notice a significant difference in fuel consumption, also.
/ BX 18 Power #4
My previous mowing machine was a Cub Cadet 2206, I loved it. It had a 20hp Kohler and 48" deck. At times you could here the motor slow down in tall thick grass if you went too fast but it was not under powered. I got a the BX2360 and there is no comparison. The BX never bogs in thickest grass at full speed in low range. I can go in reverse with bx places the Cub would not go forward. You may want to look a 2360. It has larger tires, a heavier duty front axle, and the main reason I went with it is the extra pto power. The 1860 is 13.7hp and the 2360 is 17.7. If you plan on running a blower I think you will like the extra pto power. Don't forget Kohler was one of the the manufactures that was sued for over rating the hp on their engines. Also I think your Cub is 23hp, on those model the 2 middle numbers designate power.
/ BX 18 Power #5
It's not the horsepower, it's the torque. Remove one of the BX pistons and it might be a fair fight.
And :welcome: to TBN. You've come to the best site there is to learn how to use, maintain, and (heaven forbid) fix your tractor. The guys here are awesome.
/ BX 18 Power #6
The BX 18 will eat it for lunch.
/ BX 18 Power #7
Ditto to everything said thus far. For comparison, consider 18-wheeler tractors that have less horsepower, by far, than some passenger cars. Torque is everything.
/ BX 18 Power #8
I'm amazed at the power and torque of my little BX-1500.
/ BX 18 Power #9
Does anyone try to run a brush hog with a lower hp BX? Or are they just not designed for that.
/ BX 18 Power #11
Thats about right. My BX1860 is a tank. Its so far above my 24hp Brigs twin tractor, its not even funny. Some guys get their ego wrapped up with HP numbers but when it comes to 3 cylinder diesel power, you cant compare a gas engine.
/ BX 18 Power #12
everyone has said it all . BX diesel will surprise you in more ways then one over the gas tractor.
/ BX 18 Power #14
Diesel is a whole different ballgame. I just had a new BX1860 delivered on Saturday and spent about 45 minutes on it to my total amazement! I just traded a cub cadet LTX1040 with a 19hp kohler engine. kohler was a single cylinder gas I believe and the BX is a 3 cylinder diesel which has TONS more power. YOU WILL BE AMAZED WITH THE POWER OF THE BX1860! It truly is all about the torque as was already mentioned. I drive truck and it may only have a 350hp motor, but you wouldn't try to compare that engine with say a Dodge Ram hemi with 390hp. The torque that is created from the diesel is not comparable to a gas motor. Good luck with your choice and have fun!
/ BX 18 Power #15
We have a 12 hp, 2 cylinder diesel B5100 that will thrash our 21 hp Craftsman gas job in every measurable way. We call it Little Bull.
The Craftsman does a great job cutting grass, pulling a very light, tiny trailer and toting the Cyclone Rake around for bagging leaves.
The B5100 manages to power a 300 lb, 40 in Sicma tiller and pull a 6 tine, 4 foot cultivator.
It's performance is limited by its turf tires. If it had ags or chains it would pull even stronger.
Get the BX - you will be amazed what it will do.
/ BX 18 Power #16
I had this.
23 HP twin cyl gas hog .
Had to fill it once or twice each time i mowed with it.
Then I got this.
BX1500 2 Cyl
Diesel 15 HP
Mow the yard 3 or 4 times before i need to fill it .
A real fuel sipper.
The orange one has it all over the yellow one in every way.
/ BX 18 Power #17
I had this.
Then I got this.
BX1500 2 Cyl
Diesel 15 HP
A real fuel sipper.
Don't forget the Cub only had a 2.5 gal tank and the BX is a 4.5
/ BX 18 Power #18
I had this.
Then I got this.
BX1500 2 Cyl
Diesel 15 HP
A real fuel sipper.
<sound of open palm slapping forhead>
I completely forgot to mention the greatly reduced fuel consumption!
/ BX 18 Power #19
Well, that's still almost 5 gal per mowing vs 1.5 gal per mowing. Just an annoyance of having to fill it more often because it was too small.
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A67147)
2005 MACK CXN613...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
LONG PTO 5" X 6" IRRIGATION PUMP (A64278)
LONG PTO 5" X 6"...
UM AWS-36 HEADER CART (A64278)
UM AWS-36 HEADER...
2017 Chevrolet Impala Sedan (A64194)
2017 Chevrolet...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A67148)
2013 CORPUS 40FT...
