BX-1500 Hydraulics Question
/ BX-1500 Hydraulics Question #1
DenisM
Harford County, Maryland
Looking for one now.
I was thinking about getting a front mount snow blower. The one I was looking at requires hydraulics to make it work. It is driven by the mid PTO; but needs a joy stick to lift it.
I have a load but the joy stick is attached to the loader. So when the loader is removed, the joy stick goes with it. I have been told that there was a second option for these small tractors where the joy stick stays on the tractor; any body have this setup?
/ BX-1500 Hydraulics Question #2
I was thinking about getting a front mount snow blower. The one I was looking at requires hydraulics to make it work. It is driven by the mid PTO; but needs a joy stick to lift it. I have a load but the joy stick is attached to the loader. So when the loader is removed, the joy stick goes with it. I have been told that there was a second option for these small tractors where the joy stick stays on the tractor; any body have this setup?
Well you have an older unit. It wasn't an option it was a redesign. You can still use the blower on your tractor but you have to take the loader off in a way that leaves the controls and upright post on the tractor. This means knocking out a pin that wasn't really intended for regular removal. It's the one that holds the loader arm to the upright on the right side. I know there were a few people here that we're doing this so maybe one of them could supply a picture.
Sent from my iPad using TractorByNet
/ BX-1500 Hydraulics Question #3
You have several choices.
Leave the valve on the loader when it is removed.
Make a new mount and remove the valve from the loader arm and install on the new mount.
Make a new valve mount and order a new loader valve for about $241.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
40' New Container (A62679)
40' New Container...
Lockers (A62613)
Lockers (A62613)
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
Trek (A65640)
Trek (A65640)
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
