Buying Advice Buying the right tractor for 1.5 acres
   / Buying the right tractor for 1.5 acres #11
Prices are relevant to condition, hours and local market. A B2620 will not be "too much".
You did not mention mowing as an objective. If you need to mow, that is a good package.
MMMs are brand specific, therefore quite costly.
   / Buying the right tractor for 1.5 acres #12
I don't know if a ready-made ripper tooth is available for any other brand (except maybe JD).
Michigan Iron makes a Ripper for your Kioti.
   / Buying the right tractor for 1.5 acres #14
I thought slavers had taken you.
I tried to call Agnes; no success.
I've been assembling a posse of former Cub Scouts.
And I thought you fell in....Maybe someone pushed you??
   / Buying the right tractor for 1.5 acres #15
My Wife is ALWAYS pushing me in some direction.
   / Buying the right tractor for 1.5 acres #16
I would get a BX 25, which comes with a backhoe, and forget about the mower. It's too much of a pain to put it on and take it off, and for the same or less money you can get a dedicated lawn tractor that will do your mowing quite nicely. An added feature is that you will have two seats, one for you and one for your wife!
That's a great idea what would be a cost effective zero turn mower that is roughly in the price range of the mmm?
   / Buying the right tractor for 1.5 acres #18
Well, forget about a Kubota zero turn - the prices are obscene! Just go down to Home Depot or Lowes and pick out a nice one. For 1.5 acres (and how much of that is lawn?) you don't need much. I myself have a little 36" or so Snapper that is quite old, and I must have at least a couple of acres of lawn.
   / Buying the right tractor for 1.5 acres #19
Can't go wrong with a Mahindra Max 28xl. I have about the same size property and found it works very well. I have the FEL, MMM, BH and tiller, rock rake and box blade. I'm amazed how munch I use my tractor.
1.5 acres is yard only
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
