Buying Advice Buying the right tractor for 1.5 acres
   / Buying the right tractor for 1.5 acres #11
Prices are relevant to condition, hours and local market. A B2620 will not be "too much".
You did not mention mowing as an objective. If you need to mow, that is a good package.
MMMs are brand specific, therefore quite costly.
   / Buying the right tractor for 1.5 acres #12
I don't know if a ready-made ripper tooth is available for any other brand (except maybe JD).
Michigan Iron makes a Ripper for your Kioti.
   / Buying the right tractor for 1.5 acres #14
I thought slavers had taken you.
I tried to call Agnes; no success.
I've been assembling a posse of former Cub Scouts.
And I thought you fell in....Maybe someone pushed you??
   / Buying the right tractor for 1.5 acres #15
My Wife is ALWAYS pushing me in some direction.
   / Buying the right tractor for 1.5 acres #16
I would get a BX 25, which comes with a backhoe, and forget about the mower. It's too much of a pain to put it on and take it off, and for the same or less money you can get a dedicated lawn tractor that will do your mowing quite nicely. An added feature is that you will have two seats, one for you and one for your wife!
That's a great idea what would be a cost effective zero turn mower that is roughly in the price range of the mmm?
   / Buying the right tractor for 1.5 acres #18
Well, forget about a Kubota zero turn - the prices are obscene! Just go down to Home Depot or Lowes and pick out a nice one. For 1.5 acres (and how much of that is lawn?) you don't need much. I myself have a little 36" or so Snapper that is quite old, and I must have at least a couple of acres of lawn.
   / Buying the right tractor for 1.5 acres #19
Can't go wrong with a Mahindra Max 28xl. I have about the same size property and found it works very well. I have the FEL, MMM, BH and tiller, rock rake and box blade. I'm amazed how munch I use my tractor.
1.5 acres is yard only
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
2019 GALYEAN...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2021 CATERPILLAR D3 CRAWLER DOZER (A52709)
2021 CATERPILLAR...
DEMCO SADDLE TANK MOUNTS (A52708)
DEMCO SADDLE TANK...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
