Buying Advice Buying the right tractor for 1.5 acres
   / Buying the right tractor for 1.5 acres #11
Prices are relevant to condition, hours and local market. A B2620 will not be "too much".
You did not mention mowing as an objective. If you need to mow, that is a good package.
MMMs are brand specific, therefore quite costly.
   / Buying the right tractor for 1.5 acres #12
I don't know if a ready-made ripper tooth is available for any other brand (except maybe JD).
Michigan Iron makes a Ripper for your Kioti.
   / Buying the right tractor for 1.5 acres #14
I thought slavers had taken you.
I tried to call Agnes; no success.
I've been assembling a posse of former Cub Scouts.
And I thought you fell in....Maybe someone pushed you??
   / Buying the right tractor for 1.5 acres #15
My Wife is ALWAYS pushing me in some direction.
   / Buying the right tractor for 1.5 acres #16
I would get a BX 25, which comes with a backhoe, and forget about the mower. It's too much of a pain to put it on and take it off, and for the same or less money you can get a dedicated lawn tractor that will do your mowing quite nicely. An added feature is that you will have two seats, one for you and one for your wife!
That's a great idea what would be a cost effective zero turn mower that is roughly in the price range of the mmm?
   / Buying the right tractor for 1.5 acres #18
Well, forget about a Kubota zero turn - the prices are obscene! Just go down to Home Depot or Lowes and pick out a nice one. For 1.5 acres (and how much of that is lawn?) you don't need much. I myself have a little 36" or so Snapper that is quite old, and I must have at least a couple of acres of lawn.
   / Buying the right tractor for 1.5 acres #19
Can't go wrong with a Mahindra Max 28xl. I have about the same size property and found it works very well. I have the FEL, MMM, BH and tiller, rock rake and box blade. I'm amazed how munch I use my tractor.
1.5 acres is yard only
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
