Chipper buying new wood chipper
   / buying new wood chipper #1
ihuntbear
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
looking for 8" wood chipper.All kinds on the market but don't have any experience with them.Which one to buy ? need your help.Don't want to spend money on something that won't do the job.People say walenstien $ 3300.00,some say jinma they are on ebay for $ 2000.00. .some guys say buy one with self feed.Need it for my wood lots shredding thorn bushes( 4 to 6 inch at the base ) and other tree tops and branches
   / buying new wood chipper #2
From what I have heard I would stay away from Jinma. I dont own one but have seen lots of posts with problems and complaints. Check very carefully before you buy.
8" is pretty big. I would rent one for a day. $300 will show you what you are in for.
   / buying new wood chipper #3
I would also recommend renting a hydraulic feed tow behind unit. I have owned gravity fed chippers and also a hydraulic fed unit and there is no comparison. The hydraulic fed is much faster/easier to use especially with larger diameter material as it prevents stalling. It is also safer as you can stop or reverse the feed instantly.
To chip 8 inch material is going to require quite a bit of PTO HP. Probably 40+ PTO HP. Generally if you are chipping something say 8 inches in a chipper the chipper should be designed for larger material say 10" or 12" maximum as it means less trimming and faster feed. I know my 6" hydraulic fed unit had a 25 HP engine on it and it was SLOW with 6" material.
I sold my last chipper and now have an area were I can make piles with the ends facing the proper way for me to feed them into a chipper. When I get enough piles made up I just rent a chipper for under $200 a day. It take a LOT of rentals to pay for a chipper, especially a new one. But we all like our toys. I purchased the three chippers that I have owned used and was able to sell them for what I paid for them or more after use. That may be an option to for you as Craigslist always has a large number of them for sale.
   / buying new wood chipper #4
I second what amigauser said. If you plan on doing lot's of chipping a tow behind is the way to go. Do you burn a lot of wood? Then getting an 6-8" chipper would help get rid of a lot of small stuff. As mentioned knots and crooked branches might only be 3" thick but can still get caught in the feed and have to be cut down a bit. Get a unit that has hydraulic feed would be my best advice also.
   / buying new wood chipper #5
Another fellow Canadian
I agree with the others, rent a few different models and try them. To keep up to a 8 " chipper you need a crew of workers just to keep it feed. And volunteers are hard to find unless you are going to use it for business.
Craig Clayton
   / buying new wood chipper #6
I've never had any issues with my Jinma chipper.
Wedge
i have a fifty hp tractor.Problem with renting no body here rents 3 ph units
   / buying new wood chipper #8
We have sold Jinma Wodchippers for years, no big problems at all a great value for the money, I also have a 8" Chinese self feed Woodchipper,with some added features that Jinma does not provide.E-mail me for more information if interested. We keep every part for both in stock.
tommy@affordabletractorsalesco.com
Tommy
Affordable Tractor Sales Co
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
how much and do you ship to canada
   / buying new wood chipper #10
I have this and I run it on a 3710. it works very well and has chipped a substantial amount of brush. I have put up 70 cord of fire wood in the last 3 years and it has chipped up the slash from that work as well as a lot of slash from other brush cutting.
I believe it is a Valby 150, made by the same folks who make Farmi logging winches.
This thing is VERY stout and robust. I have owned it for 12 years and had zero issues with it.
He picture on the right is the most accurate one I could find on the internet. Aparently Valby now calls this model the CH 150 HF (hydraulic feed). Mine is a two stage hydraulic feed. I find it best to make a big pile of brush and then stand there feeding the chipper......... It makes very fast work out of a LOT of brush. nOisy though, I wear ears when running it.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
Concrete Mixer Mini Skid Steer Attachment (A55851)
Concrete Mixer...
Pick up bed (A55973)
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
