Buying my first tractor
/ Buying my first tractor #41
Looking and owning one are different things. Being that you don't have experience on owning any of those, why the constant bash on these brands? I just don't get it.
No, I didn't look at a RK tractor because we don't have Rural King stores here. Although, I have looked at the TYM tractors, being that RK tractors are just rebadged TYM tractors, it makes pretty much the same, and saw nothing wrong with those either. In fact, they are heavily built and come with a lot more stuff standard than some of the premium brands, where everything is an option.
Since you looks at the RK line, what's so wrong with it?
In a nut shell:
What is wrong with RK tractors?
They are being sold (and maintained?) by a "big box store" seller, who is not a tractor manufacturer!
To use a colloquialism: The retailer does not have a real horse in the race.
Like Cabellas (it is likely there was never a Cabellas in Portugal either), RK, as a seller of tractors, is very much a long term unknown.
If there is zero possibility for the Cabelas-TYM history to be repeated, then my concern is unfounded.
Perhaps the TYM-RK marriage is truly one made in heaven......I am simply not nearly as certain of that as you must be.
A TYM-RK divorce would very likely have a meaningful effect on the 8 year warranty support, and the ongoing value of RK tractors.
I’m standing up one house at a time, the lumber will be close to where it’s needed. I’ve always had to pack lumber from the pile to the slab, just limited by what I could carry. I’m not moving lumber between multiple lots.
The tractor I’m looking at right now is a 35hp machine, it’s quite a bit larger but may still be considered too small for a lot of jobs.
/ Buying my first tractor #43
I’m looking at a Mahindra 1635 HST with several attachments for under $20,000. It has a 60” brush hog, forks and 60” box blade included along with the loader on the front. It seems like a great deal, any input on Mahindra tractors would be great.
Would you buy a car made in India? Of course not. Same for a tractor
/ Buying my first tractor #44
I used to do landscaping and minor construction on new homes a couple of decades ago, so I'll offer my two cents. I was in the Ozarks at that time, so soil conditions don't match what you have described in your location. Both a tractor and skid loader can trench and grade ok as well as move materials. If you compare a tractor with ~35 hp to a similar weight skid steer with about the same power, they can get about the same work done. As you go up in skid steer size and hp they scale real well on a job site. The skid steer at 65 hp isn't much different in size than one at 35hp, but it moves faster and hauls more. It's tough to scale up a tractor as easily because it isn't as maneuverable. That can all be somewhat dependent on your conditions and construction time frame. The houses I was involved with all had walk out basements and they were popping up like mushrooms. All the subcontractors were trying not to trip over each other.
All that said, I think a tractor works very well for moving bulk materials with the bucket like top soil, gravel, or mulch for landscaping. A box blade can do amazing grading work for a lawn if you know what you are doing. The bucket on a tractor doesn't have the downforce to really do much with the base soil or subsoil. All the weight is on the back and it feels like you're trying to dig a hole with a plastic spoon if you use it for that. My only advice is to understand that the tractor won't do things as fast as a large skid loader.
/ Buying my first tractor #45
The old Mahindra were built like a brick outhouses. The only problem was that nothing was readable with the gauges. I have no idea if the new ones have that kind of build quality. I doubt it, since everything is so much cheaper and flimsier these days, but I wouldn't discount them on the premise that made in India means its automatically a pile of crap.
/ Buying my first tractor #46
You need a CTL and a mini excavator. There’s a reason you don’t see more compact tractors on construction sites: they aren’t really suited for that type work. Compact tractors seem to primarily be suburbanite toys more than machines that you make a living with. I include myself in that group of compact tractor owners.
Unfortunately, your budget isn’t going to get you what you need.
Buying a tractor so you have it in the event you buy a lot and build doesn’t seem smart either. Consider that you moving may never happen. It’s a wish now, unless you have contracts in place.
Buy what supports your business, and let mowing your five acres justify its own equipment when the time comes.
/ Buying my first tractor #47
This is a used purchase from an individual. I don’t know if he bought all the implements as a package or individually.
Ah ok that could be better then. Just make sure you get the brands/model numbers to look up prior If you go that route.
/ Buying my first tractor #48
You haven't seen the Blue LS tractors??
From what I have seen they are very well
made with options that are standard! I
would suggest checking out other tractors
before you buy. You also need to check the
height that the bucket will reach especially for
construction work. Its your money you will have
to live with what ever you get so be sure to check
out all the tractors that you can before you make
a decision!
willy
/ Buying my first tractor #49
In my mind one of the construction grade Kubota B or L machines would be perfect, like a B26 for example. They are hard to find though and harder yet at the OP’s budget. John Deere also made construction grade TLB’s that were smaller at one time.
/ Buying my first tractor #50
JD marketed their construction grade 110 TLB units between 2000 - 2012, and they are very fine machines,.... with one exception.
They have a somewhat spotty history of transmission cases cracking.
I really wanted to buy a JD 110, but the potential for that issue scared me off.
I found a very low hour Kubota L48 TLB (251 hours), and bought it instead.
/ Buying my first tractor #51
Hmmmm, well I can tell you my experience with building a "slab" house on grade with a tractor. I own a LS XR4046 with loader and my tractor did all the excavation work for our retirement home we are currently building. When I say excavation work, I mean basically all loader work done to remove top soil (we had 12" topsoil until it hit gravel), after top soil was removed used tractor again to fill up for what is known as a "frost protected shallow foundation" or better known as an insulated floating slab home, a 1208 sq ft home. My tractor is rated for 46 hp plus the loader isnt too shabby with capacity, HOWEVER....when you are doing extensive loader work and you are in a hurry or have time constraints, my suggestion is a skidsteer of sorts for faster work and with a skidsteer you could always mount a backhoe on front for smaller projects. Yes my tractor did the job and saved me a ton of money but time wise it takes longer than using a skidsteer. Now if my tractor had a backhoe, it could have dug the trenches for the electric, well water line, and septic system, albeit slowly, after all my time is my money and I decided to save on the money part and use the time to work in a pace that matched the tractor. I had to borrow a backhoe for the electric line, and just went out and bought a used TLB because to put a backhoe on my tractor would have been 7k give or take so I just added a little more and got a good used TLB for dedicated construction work and plan to use it for water line, septic system, and future construction projects on our 20A farm land. Most CUT's are capable of doing what you need BUT they will wear faster and the dedicated construction machines will have a better resale value should you decide to stop doing the construction etc. Just my thoughts on it.
/ Buying my first tractor #52
ereicmb. I've been around construction all my life and if you want an all purpose tractor you should look at a yanmar, jd or kubota construction backhoe. As some have mentioned the JD110, Kubota L35,39,48, M59 TLB series and Yanmar cdl40 were all designed with heavier frames and loader arms, larger hydraulic pumps and etc. They won't replace a larger skid steer or excavator but are a good all purpose machine. I have run a Kubota B26 quite a bit and although a very good machine for its size, will be underpowered for the tasks described.
I have a L35 that has dug several foundations. It was slower than a skid steer or dedicated excavator but did the job and gives me the flexibility to throw a bush hog or box blade on the 3 point when needed.
/ Buying my first tractor #53
I’m thinking about buying a tractor to build homes with. The homes will primarily be slab homes with a possibility of a walkout basement.
In the past I’ve rented or borrowed skid steers for the work and I’m thinking of buying my own equipment. My wife and I live in a small city on a lot and we’re looking at buying 5 acres or more in a few years. That’s where the tractor comes in.
I was thinking a tractor with a loader and backhoe would meet the requirements of home building and we would add a mower deck in the future.
What advice would you have on the type of tractor to purchase? I was thinking between 35-40hp but I’m not sure if 25hp would work as well. If I can use the tractor for all but digging out a basement it’s not the end of the world. Most slabs around here require a 12” bucket and 30” deep or so. I would be building homes on lots, not acreage if that matters.
I was an equipment dealer for years and I have o say that you have to get clear on what you mean by tractor. If you are planing on excavating actually digging with the tractor then you will need an industrial tractor. Ag tractor loaders are designed to scoop and move material. You will destroy it trying to dig with it. If you plan on doing a lot of digging an excavator is a far better way to go then a backhoe on a tractor. They are faster and far more maneuverable.
/ Buying my first tractor #54
I think you are right, even with my tractor (LS XR4046) and teeth on the bucket...it was hard to break up the top of the topsoil layer, so what I had to do first was use a 3pt tiller over the whole area to break up the hard packed top soil and then it was scoopable with my tractor. It is doable with a CUT but again a dedicated construction machine is much better if a person plans to do this type of building for a living etc. I bought a good used (even tho' its older) JD 410 TLB and this thing can dig and move dirt like crazy and its built to take the abuse.
/ Buying my first tractor #55
One other thing to consider, if you bought a dedicated construction machine, they are heavier and have great ballast....my tractor did lift my pre built wall sections in place without sheathing on them, had to put a 2x6 perpendicular screwed into studs so that my forks could lift the 8' sections in place. Worked, but if I would have had my own skidsteer or the TLB I could have done that job just as easily PLUS could have bought a "truss pole" to help with lifting and placing trusses. I wouldn't have tried a truss pole with my CUT, they were 30ft wide trusses so rented a manlift and put swivel chain on it to lift the trusses up in place. this is where dedicated construction equipment will come in handy...a skidsteer with a truss pole can do a lot of truss install, plus lift sheathing up to be installed. With higher flowing hydraulics there are many attachments that can benefit construction site.
/ Buying my first tractor #56
I'm thinking small excavator. If you are thinking an Agricultural tractor with FEL and Backhoe attachments. I think you will be disappointed. They don't have the lift. You'd be better off with something like the JD 110 or JCB MIDICX. They have a real construction toughness and lift capacities. still the excavator with its 180degree rotation really helps when find room for sort you are digging.
/ Buying my first tractor #57
I have an old 50hp (PTO) Massey-Ferguson tractor with front end loader. I think it is too big for what you want, mostly too big for easy transportation on a trailer even without the backhoe. 35-40 hp (engine) would probably be good, make sure you have a way to get it to your construction sites. A mini tractor is easy to transport but probably too small for construction work. Yes the tractor front end loader is not intended for use as a bulldozer, but it can move or arrange dirt and other objects. The backhoe that you want will work for most digging, especially trenches if you have the right bucket. Depending on how much dirt you are digging out from under a house, you may need to rent something better, but the tractor will still be useful for everything else.
You will want a utility tractor, not a farm tractor. The difference is in the transmission, where the utility tractor needs a synchro-shuttle that moves instantly between forward and reverse and all speeds are available in both directions. Mine is a farm tractor with 4 forward and only 1 reverse in each high/low range, not as good for repeat motions moving scoops of dirt. Mine also has farm "AG" tires, better traction when pulling but will tear up the ground perhaps more than you want, less aggressive tires may be better.
I do think I’m going to look for a loader as that’s been the consensus so far and as someone else said I can likely sell it and get my money back out of it. I don’t have a way to haul the loader, but where I’m building the houses is less than 2 miles from my house, so a loader with tires instead of tracks will do.
It’s funny, I read somewhere else that a Case 1845c runs great and the 5 year old message board I found said paying $10,000 for one should be easy to find (again this is five years ago). There’s not many for sale around me today and they’re all $15,000 or more.
I’m quite confident a tractor would work for my needs, it would just be a bit clunky. I’m not a rush rush rush kind of guy, but I am about efficiency. Other than scraping the vegetation off the surface I’m not looking at digging with the loader, just picking up loose dirt and spreading it around.
Having the tool on site would make it easy to use, therefore more efficient than renting or waiting on someone to do it for me.
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A60429)
2019 CATERPILLAR...
5' ROTARY MOWER (A60430)
5' ROTARY MOWER...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2017 SANY SY365C LC EXCAVATOR (A60429)
2017 SANY SY365C...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
