Buying MX6000 Cab
/ Buying MX6000 Cab #1
Little Mac
Bronze Member
Chicagoland
2007 MF GC2310TLB
I am looking to purchase a new MX6000 Cab, and my dealer seems to be doing ok on price, but not very helpful in optioning out or just general assistance in options. So I have a few questions.
I need the third function for a grapple, but I am not completely sure on what rear remotes to get. He just told me the first is 1000, 2nd brings it up to 1500 and the third rear remote would be 2K total for all three. Is it wise to get all 3 at this time or can these be added later when needed? Currently I only plan on using an offset flail mower.
This unit will be located in northern Wisconsin, so I am wondering if the rear defrost and rear wiper would be a good idea for winter use. Has anyone have an opinion on those two? Same goes for the block heater, That seems $$$ but may be a well worth option.
What seems to be an honest price for having the tires filled? looks to be about 57 gallons per tire
Any options that are a must? I am coming from a much smaller sub compact and out grew it years ago. This will fit our needs great.
I really appreciate all the help and opinions.
/ Buying MX6000 Cab #2
Looking at online prices, that seems like more than a fair price for those especially installed. Yes you can add more later if need be, and it's not super hard to do but at the price you're quoted I'd probably bite the bullet and get as many as you think you'll ever want. If you get two or three I'd get one with a float option (that might increase the cost a smidge). Two might be nice with the flail so you can do hydraulic side shift and a hydraulic top link at least... at which point three isn't a lot more :D
You might look at a stick on oil pan heater, I think that gets you 90% (or maybe more) of the benefit with a lot less cost.
I'm surprised the drawbar is optional on the configurator. I'd get that, the grill guard (or a third party grill guard) since you're doing grapple work, and the bolt on bucket edge (again or a 3rd party one..).
/ Buying MX6000 Cab #3
I regret not getting 3 rear remotes when I spec'd my new tractor 9 years ago. I have 2 rear remotes, and with my blower or ditch bank flail I have to remove the hydraulic toplink and use a manual one.
Everyone's needs are different though. There are various aftermarket hydraulic options available to add a remote, or split existing remotes but I prefer the generally cleaner installed OEM remotes.
In your area I would recommend a block heater (I added one at the first coolant service for $70, and it's not a difficult job.
The rest of your list : defrosters and wipers will be useful, as will be the fluid filled rears. I had the dealer add all of these options prior to delivery.
/ Buying MX6000 Cab #4
Take a look at the bucket options - the HD round back bucket with bolt on tooth bar are a step up - not sure if the standard bucket has the bolt on edge capability? Also simple things like armrests on seat etc.
/ Buying MX6000 Cab #5
I have three rear remotes on my Ford with T&T cylinders. I thought that would be enough for the T&T and a drawbar implement to raise it up on wheels. When I got the ditch and bank mower, it was obvious I needed to do something else. I got an electric diverter so I can run the T&T on a single valve. That leaves two open valves (remotes) for the mower. It's going to be busy under the seat, but I won't have dangling hoses when pulling the top or tilt cylinder for the extra line set.
/ Buying MX6000 Cab
Take a look at the bucket options - the HD round back bucket with bolt on tooth bar are a step up - not sure if the standard bucket has the bolt on edge capability? Also simple things like armrests on seat etc. Armrest would be nice, on the fence if I need the air ride seat.
He quoted me for the HD Round back bucket, it is the L2296. That should be predrilled for cutting edge but I think the cutting edge is another option. I think the armrests are a great add, I will add that. Thank you for the input!
/ Buying MX6000 Cab
That's exactly what I was wondering, I suppose I can just order it with the three rears and be set for future attachments that may require them. wiper and defrost isn't too bad of a price tag, just wasn't sure if it would be totally not needed. I use a front mount snow blower on my little massey and it is fantastic, but being in the open isn't so fun. I figure if I did a rear snow blower the wiper and defrost would be really nice.
Thanks for the help!
/ Buying MX6000 Cab
Good advise, and I am also surprised that the little things are all options, but I suppose these are economy tractors, I could go with a grand but I prefer the simpler stuff. The MX isn't as nice but I think it will work great for our needs.
/ Buying MX6000 Cab
So my dealer has me quoted out with the MX6000HSTC with 3 rear remotes, #2 is a float, third function up front, rim guard filled rears, LA1055 Loader with HD bucket L2296 which is pre drilled for cutting edge. R14's, Rear wiper, Rear Defrost, 130a Alt, Side mirrors, block heater but not the CCV heat option.
Items I would need to add is the drawbar for hitch, arm rests, radio, easy to do after the fact though.
He has this unit on the lot, has had it about 6 months. Question is price, This is coming in at 60k plus tax. I am just wondering at this price point if this is a good unit vs going for the Grand L, my main thing is I need the lift Capacity for picking up trees.
Maybe I need a spend a little more on the grand? I am wondering if I will kick myself for not getting the HST+ and the lower fuel fill is really nice on the grands. Always a tough call.
/ Buying MX6000 Cab #10
Yes, get the 3 remotes at the time you order your tractor. I added three last summer to my MX6000 and it costs more than you are being quoted doing it afterwards. IDK about price that you are being quoted. I bought my ROPS model in 2021 for $39K. As for the HST+, I’ve never used one, never felt like the standard HST in the MX was lacking anything I need. Overall I really like the MX platform.
/ Buying MX6000 Cab #11
You should really try out the HST+ if you haven't already. The hi/lol in 3 ranges is a great feature, as well as the other electronic transmission controls.
/ Buying MX6000 Cab #12
I haven't ever seen it myself so looked up the messicks video on HST+. Interesting stuff
/ Buying MX6000 Cab
I really want to, but he doesn't have any currently. I do have another dealer but he is about 1.5 hours away, but he does have a bunch of grands i could try. After watching that, it seems like a road trip is in order. You guys are going to be costing me more money :ROFLMAO:
/ Buying MX6000 Cab #14
Glad we could help :ROFLMAO:
Seriously my MX5200 is capable and the easiest tractor to operate I've owned.
/ Buying MX6000 Cab #15
I’ve purchased two Kubota’s in the last 8 years from the local dealer. In both cases he didn’t have it in stock but got it from not to distant other dealers. In the first instance he just put his dealer sticker over the first’s. 😆
/ Buying MX6000 Cab #16
Just like buying trucks. I went with a friend to pick up a new truck. WHile shooting the breeze I mentioned I would buy one if it was exactly what I wanted... He asked me what I wanted and wrote it all down. 2 weeks later he called me to come down and take a look. It was exactly as if I had ordered it. (y)
/ Buying MX6000 Cab #17
Isn't the FEL lift capacity on the Grand L and the MX essentially the same?
/ Buying MX6000 Cab #18
The HST+ is really neat.
Get at least 2 rear remotes. You mentioned "snowblower" -- get the rear defrost and wiper. You need worklights front and rear but might find that you can add your own LED lights cheaper than the dealer option. Comfort stuff like armrests and side mirrors are no-brainers -- get them. HD alternator - yes.
I'm trying to understand the marketing model for the MX vs the Grand L tractors. As you point out, it seems like the MX will cost as much as a Grand L by the time you add all the comparable options. (And you still won't have the HST+ option.) Is the cab a lot nicer in the MX? What are the strong points of an MX6000 vs a Grand L6060??
Whatever you decide, just do it and don't look back. It'll never be any cheaper than it is today. (On the other hand, seems like hard times are likely for a while. A cash buyer might want to watch for a nice used unit.)
Good luck.
Edit: Forgot to mention . . . The 3rd function up front is a must-have so be sure to keep that on your list!
/ Buying MX6000 Cab #19
I have both an MX5800HST and an L6060HSTC. These are my thoughts:
The MX uses an LA1065 FEL and the Grand L an LA 1055. There is a difference but not much. I much prefer using the MX for earthwork due to it's larger tires and slightly stronger frame.
As I mentioned earlier, I considered an MX6000HSTC as a second tractor before getting the L6060HSTC but the MX with cab isn't compatible with my BH92 hoe. IMO, the cab on the MX isn't quite as fancy as the Grand L. If you log a lot of seat time, you'll appreciate an air ride seat as well as the added features of the Grand L.
I also looked at the MX5400HSTC, but decided the added HP of the 5800 would come in handy for the brush cutting I do.
I learned a long time ago that the more remotes you have, the better. This is especially true if you plan to get a T&T kit or even just a hydraulic top link. Yes, you can use cheaper diverter valves, but they can be tricky to operate from a cab.
If you plan to use a rear mount snowblower, The rear window defrost & wiper are a must! I also find them useful when grading muddy or dusty roads.
For the most part, Kubota tractors are good cold starters. If you keep the tractor inside a closed building, even an unheated one, a block heater may not be necessary. I keep mine inside an unheated barn and don't use block heaters. I have never had one fail to start, even on sub zero mornings.
Many choices, and a lot of decisions to make. Don't just buy for what you plan to do now. These tractors can last a long time so keep the future in mind as well.
/ Buying MX6000 Cab
Everyone has added some great info on this subject and I appreciate it.
I contacted my Third dealer who had a new 2023 L4760HSTC with no time on it and will sell at "invoice". So I get a qoute and all is looking good, then there are the fees, 7500 in fee's that no other dealer is charging. I like the 4760 with the HST+ and the lower level fuel fill and external rear lift arms. But with the same addons as the MX the L is still more by 7K. Assembly fee is 5400, Transport fee 1500, Kubota Finace filing fee of over 600. Is this normal and the other 2 dealers forgot to add to the invoice? I am not sure if a lower HP tractor is worth the extra money and is been sitting for 2 years. I understand dealer needs to make money, but these fees seem excessive. Am I wrong. I will contact them back after I hear what others have experienced.
Thanks everyone for all the guidance and help!
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Brent 420 Grain Cart (A61307)
Brent 420 Grain...
Sakai SV505 (A60462)
