buying input
   / buying input #11
I think the B21 is built a lot heavier, John....almost construction grade. Nothing wrong with a B2710, but the B21 was made to take some abuse.
Doesn't sound like you're planning any field work, traildog, but be advised that the small tires on a B will give you a bumpy ride on rough ground. This may not bother you, but I found small bush-hogging jobs with the B7610 to be a trial. Had to go slow to keep from being tossed all over the place. Concluded that field type work is best left to larger machines. If your back is bad, you may agree.
Bob
I don't really know the difference between the B model with the made to attach BH vs the comes with BH like a B21 vs B3200/B3030. My understanding is the frame from front to back is heavier or reinforced on the comes from factory with BH. Not sure how much heavier/sturdier. My point is the value of a nearly as heavy duty??? new machine with full factory warranty and with 0% 42 months financing vs a pay cash/get regular financing heavier duty framed machine with no warranty and 500 hard? 500 easy? hours. I usually buy new so my preferences are obvious:) and I can't forget the words of wisdom a tractor man with years of experience told me before I bought my first tractor...."You don't want a used tractor" is what he said and then he walked away. Now I've returned to the fold 7 well cared for Kubotas and I wouldn't be afraid of them but I know their life history. I don't know if someone like my brother owned the other ones. My brother can tear up a steel ball and he always services his stuff on schedule if it's still working at that time.:) I don't think they would be as far apart as (B21)Apples vs (B2710)Oranges but I could be wrong and I have been before and will be again. I'm seeing maybe a sealed black plastic bag that states 100 apples vs a web net bag stating 50 visible ripe oranges.:D
   / buying input
I wont be doing any field work...All cleaning timber,backhoe and loader work.I finally got my rental dropped off before dark.They actually paid a customer drop it off.So lazy.I def wont be buying from them...The guy that dropped it said go with kioti.And he also recommended a dealer I went to few weeks back.Was leary of the hour drive for parts.But really not bad.Really liked the b21 but not sure if I should just go with new..But cant afford the 600 dollar payment on the l48 thats in my town forsale ...My local dealer stock sucks.Asked for a b26 and he couldnt get one..lol
   / buying input #13
If you are looking at an L48 TLB to do your work then a B model is going to be a disappointment in many ways.
Talk about comparing apples to oranges.
   / buying input #14
Traildog,
You seem to be actively looking but unsure of what to get.. The L48 is a lot more tractor than the B21, and the Kioti are good units but I dont think they have a dedicated TLB line similar to the B21/L39/L48 of Kubota.
You might want to see if your local guy will let you rent/test the B21 for a weekend so you can do some trial runs, then visit the Kioti dealer as well to start to narrow your selection.
Also, if you have a location put it in your profile as there are probably TBN members in your neck of the woods that can offer suggestions and dealers etc.
Bottom line if you are spending $20K+- you should consider all your options - new/used as the finance side of things 0% on new.
   / buying input
As I stated the only tlb close to me is an l48.The dealer couldnt get me a b26.Go figure.I was sure I was buying the used b21. Well the rental I got is a ct235 not ct 335 as I was told.I like certain things.But hate the backhow mount being so far out and the frame work gets caught up to ease in snow.The backhoe wont even lift the rear of the tractor off the ground.The b21 would lift it up and set it down to the side.Great if you get stuck.This thing is not something id buy.....Kioti does have a tlb but never heard good or bads about it...So far ive only had a kioti dealer offer for me to even drive one.I think the guy with the b21 has so much money he could careless who buys a tractor.Does have great selection though.And all nice units.
   / buying input #16
Have you considered an L39? It would do the jobs you anticipate better than a B26 and can be found used at a decent price. That model is quite versatile and has 50% more power. It has the ground clearance for keeping the undercarriage out of the snow. Getting it into a garage would be an issue.
As an example of the price, two are listed here on TBN for $24K to $25K. They would go for cheaper with a little bargaining.
Nothing against the B26. It is a great little machine also.
   / buying input #18
Considering the condition and hours it seems a reasonable price.
I recently got my '91 B20 w/ 750hrs for about half of your price, but I'm
going to have to spend some more to get the PTO fixed.
Another consideration is that you may find a unit at a better price
somewhere else, but how much will it cost you to get it home?
Where the thing is is definitely a cost factor.
Have fun,
Dennis
UNUSED CFG INDUATRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
2010 Toyota Camry (A50324)
2010 Toyota Camry...
EZGO GOLF CART (A50324)
EZGO GOLF CART...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
