buying input
   / buying input #1
traildog
Johnstown,PA
Looking at getting a 2007 b21 for 20,000.Any input on this tractor for personal use.Got about 6 acres,want to clear trees,maintain pond.Put in some french drains,etc.Thanks
   / buying input #2
Does it come with a BH & FEL for that amount?..how many hours and condition?
   / buying input
500 hours and perfect looking conditon.Doesnt look beat up.I didnt operate it ,as 50 inches of snow and its in showroom.Was gonna before signing papers.It does come with both fel and bh.
   / buying input #4
Can't give much input on the price..Looks kind of like a new one of a similar size runs around 28K, but I'm not sure.
The B is a nice machine, a step up from the BX in terms of size.
You won't be able to mow over trees of any significant size, but you can work on the stumps with the BH. Pond maintenance, depending on the grade, should be a go as well.
You'll like it. My BX is set up in a similar way, except I have a MMM as well. Paid almost 20K in 2004 for mine. So make of that what you will.
They are very durable and have very few issues. DIY maintenance is nice too.
   / buying input #5
B2710HSD w/ loader and backhoe - 6 hours, new condition, warranty, leftover unit, $19500
Used Kubota Tractors
This is a new leftover tractor with full warranty and 0% financing.
I saw it and it looks great. Contact them and see if you can't make a deal.
   / buying input #6
I've had the B21 now for 8 years and its a tough machine - my uses on 6 Ac are building rock walls, doing landscaping, digging out trees/stumps, trenching, hauling and grading. In the winter I have the rear blade for snow.
It has its limits especially stumping in rocky soil, I have learned to get a proper excacator to do that for anything over 12-14" -sure it will dig a 3' stump - it just takes time. I regularly push over 4-5" black birch or pines with no issue with the FEL when I want to clear a path/trail.
It goes though the woods great - its size is easy to manuever around and it has a full steel plate under the tractor preventing limbs and other things catchiing.
Overall for the size it's lifting and digging strength exceed that of larger units, and the frame and overall construction is commercial grade.
Price you have is maybe a tad high - new they were $25K range. As John Thomas points out Barlows has the B26 with 229 hrs for $24,500.. thats a step up from the B21. Then the 2710 HST is a nice unit but slightly different in design than the B21/26 machines.
   / buying input
Thanks guys.All input appreciaated.Was supposed to be getting a bocat ct335 rental dropped off for moving snow today.But never showed.Was concidering them.But lost my businees now.
   / buying input #9
A B2710 and B21 are not in the same league.
Its a fair price for a used B21. Not stellar, but fair.
Would the 500 hours vs 5hrs with new warranty and 0% 42 months financing put them in the same league or close? In my calculation, money wise they are not in the same league and hours of service already done to one also has them in a different league. Just my opinion from the customer side and not the selling competeter side.:)
   / buying input #10
Would the 500 hours vs 5hrs with new warranty and 0% 42 months financing put them in the same league or close? In my calculation, money wise they are not in the same league and hours of service already done to one also has them in a different league. Just my opinion from the customer side and not the selling competetier side.:)
I think the B21 is built a lot heavier, John....almost construction grade. Nothing wrong with a B2710, but the B21 was made to take some abuse.
Doesn't sound like you're planning any field work, traildog, but be advised that the small tires on a B will give you a bumpy ride on rough ground. This may not bother you, but I found small bush-hogging jobs with the B7610 to be a trial. Had to go slow to keep from being tossed all over the place. Concluded that field type work is best left to larger machines. If your back is bad, you may agree.
Bob
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
Ih 490 Disk (A50514)
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
