Buying House with Septic System
   / Buying House with Septic System #71
I love our garbage disposal, but we are on city sewer. We don't intentionally put food down it but it is super nice not having to empty a sink strainer. Just rinse it all down the sink until it starts to back and flip on the disposal. Such a luxury!
If you only use them that way, you're generally ok. They become the proverbial plumber's best friend when people try to mulch/slurry up everything with them.
  • Good Post
Reactions: JJT
   / Buying House with Septic System #72
Home was built in 1965. Conventional tank and leach field. 30 years ago, I had a home inspector before we closed the purchase. He filled the tub and then let it drain. Based on the backup/slow drain, he recommended a new leach field. A new field was installed. Since then, I've pumped the tank every 3 -5 years. The hard rule here is only toilet paper and what was eaten goes in the toilet. Cooking grease is collected for the trash. Haven't any issue with bleach or such in 30 years.
PS: I did install risers on inlet and outlet to avoid digging and landscape disturbance.
   / Buying House with Septic System #73
Island County in WA State doesn't allow disposers in new construction and hasn't for about 20 years. Maybe more. Island County also doesn't recommend additives. The reasoning being that the additives liquefy solids that then precipitate out in the drain field. And you cannot find the typical septic additives for sale in any of the stores on either island, Whidbey or Camano. With most folks in Island County being on septic systems the health department really pays attention to septic issues.
Eric
   / Buying House with Septic System #74
Years ago I was moonlighting for a caterer on a busy night. Things got crazy, the chef had to dump the grease off a steamship round so that he could serve it but the sinks were full of water and dishes. The only one available was the one with a pig... which quickly cooled the grease, plugging the drain. We needed the sink so I had to reach down it to drag the grease out.
I cleaned with my right hand while clutching the biggest knife I could find in my left to keep people away from the switch. If he was stupid enough to do that who knows what else he would do.
   / Buying House with Septic System #75
That test was useless. My tub drains slow if theres hair in the trap
   / Buying House with Septic System #76
I wonder, in a finished house, how would an inspector even know sinks and tubs wernt piped into septic?
   / Buying House with Septic System #77
I am wondering just how an inspector would know "if" certain drains were bypassed away from the septic tank. A couple of mine were actually diverted to dump on the empty lot next door by the guy who built the house. I found it when the grass clogged the pipe and I had to track the pipe. Short of putting dye in the water and making sure it flowed into the tank, how else would you track to make sure the waste water actually went into the tank? On new construction, you can still see the pipes before they are buried, but once they are buried, how do you tell? Most inspections just want to make sure that there is enough flow to keep the tub empty and the sinks from backing up. Maybe run a load of laundry to check that, but how many pull the lid off the tank to check to see if the flow is coming into the tank?
David from jax
   / Buying House with Septic System #78
Our OP specifically stated the washing machine was just piped through the wall.
If you Really wanted to know, you could easily drop a die pack, and open a clean out.
But, to your point, you absolutely can do it, Noone will likely ever know, as long as you dont pipe it to the road or something. In the end though, you have to pipe it somewhere, and its not hard to find a 2" PVC pipe, and question what it is.
This is mostly just a selling/buying issue; not a does it work or not issue.
   / Buying House with Septic System #80
If you want to get away with stuff on a new build, its not hard. Yes, you have all your MEPs underslab inspection, and pre-pour inspection. Nothing stops you from changing things around post inspection, pre pour. No one will ever be able to see as all your piping is under the slab, and never visible again. You could then hide and cap the gray water, as you will need to fill the DWV for the rough in inspection. Its just more trouble than doing it per code
You would pretty much have to be an owner builder, though. Plumber isnt going to do it, GC isnt going to let the owner go dig and cut and move stuff on his house, etc.
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
1518 (A57192)
1518 (A57192)
2015 Ford F-250 Auto Crane EHC32 3,200lb. 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
