Buying a ssqa plate
/ Buying a ssqa plate #41
He is based in China, that might slow things down right now:
/ Buying a ssqa plate #43
Well, I have what I have, so I'll just have to make do. Also, this:
I have a similar unit, I would not try to do that project with it.
Search Craigslist and marketplace for a used stick welder buzz box. If worse comes to worse for power access for 240 volts, run wire (10/3) to your welding location from your dryer outlet and put the necessary ends on the wire. Unplug your dryer when you are going to weld then when finished plug the dryer back in. This will prevent a possible overload of that 30 amp circuit by having both running st the same time. Of course if available, run a new circuit for the welder.
A stick welder similar to your flux core will be much less effected by wind than a gas based mig welder.
/ Buying a ssqa plate #44
Wrong seller, the ones we bought were from a seller that show Australia as location.
My bad. When you reported problems, I went back to re-read the thread and used the second link in your post #8:
Thanks. Yeh, I did check out Titan. I also found this and to go really cheap, this.
Should have read farther and found the link where it was ordered.
/ Buying a ssqa plate #45
All good, the 15th I expect ebay to refund me. Honestly it seemed like a scam but with ebay/paypal its worth the try.
/ Buying a ssqa plate #46
....Honestly it seemed like a scam...
Sucker born every minute? ...And this is the reason scammers from around the world continue to do what they do... scam people who are gullible. You keep feeding them, they will never go away... (not that I really think they will actually stop)
The Craig's List scams are getting better, values that are a really good deal - harder to spot the fakes ones vs. real ones.
Calm down fella, nobody is a sucker here, everybody here thought it was probably bs. Ebay refunds you if it's a scam, so there's no loss.
Ok well, my drier is gas, and I will do this project with this unit because...what's the worst that will happen? I break a weld while plowing my driveway? Big deal, I'll just reweld it right there on the spot.
/ Buying a ssqa plate #49
Ha! I saw the ebay sellers name and it looked familiar. I bought something different earlier this year from that person and lucked out. It was shipped quick and everything went fine. Whew!
What you get from him?
/ Buying a ssqa plate #51
Which seller? Theres been a couple mentioned. I think the one we bought from only had 2 prior listings.
/ Buying a ssqa plate #53
I bought a pair of traction boards from flashemotor.
I don't think there was any issues with flashmotor, the ssqa plates that we bought were from a different seller.
Hey, if any of you left a ebay review on this guy, go back and make sure you did that correctly. There are people who wrote negative comments on him, but rated him positively by mistake.
I have my issues with ebay, but I must say they make buying on there a safe bet. Purchase refunded, case closed.
/ Buying a ssqa plate #56
Probably not done by mistake! Ebay makes you do the cha cha-tango-charleston to leave a negative feedback. Lots of people will rate positive but slam them with comments and give poor star ratings to circumvent Ebay and there policies.
Me included!
Me included!
No, only as a seller...nearly impossible to leave negative feedback for a buyer. Yet another reason why selling on there kinda sux. But, as a buyer for leaving reviews, you've get 3 options (positive, neutral, negative), and then you write the comment. Quite possible though, if you don't choose one of the options but just write the comment, it automatically selects positive for you.
2019 Carry On Dump Trailer (A62613)
2019 Carry On Dump...
New/Unused ATS Mini Excavator (A65583)
New/Unused ATS...
1998 Reids 20' Lowboy Trailer (A62613)
1998 Reids 20'...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
John Deere 1790 Planter (A66285)
John Deere 1790...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
