Buying a Farmtrac 665DTC...should I?
   / Buying a Farmtrac 665DTC...should I?
Thanks for the heads up Clint. That's sounds worth an oil drain.
   / Buying a Farmtrac 665DTC...should I? #32
From looking at the parts breakdown, it don't appear that the 555 DTC and 665DTC have the same transmission, case, gears and etc. Maybe someone has more knowledge about these tractors than I do. I did look at the 665DTC pretty close and I don't see an inspection cover on the side of the rear end case. However, I do see a round cover on the 555DTC rear end picture.
   / Buying a Farmtrac 665DTC...should I? #33
Could very well be, I have never seen a 665, just going off my issues with the 555. Just assumed and you know what they say about that.
Maybe it is different enough that I won't have the problem. I did check the parts manual breakdown and I see the pinion bolts, doesn't appear to have any lock on it. When I'm back over at the farm I'll take a look at the inspection cover.
33ft Dovetail Flatbed Trailer (A56435)
33ft Dovetail...
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
2008 International 7500 T/A Altec A77T 76ft. Bucket Truck (A55973)
2008 International...
2017 PETERBILT 579 SLEEPER (A58017)
2017 PETERBILT 579...
2005 International 4300 Telsta Bucket Truck (A55973)
2005 International...
HUSQVARNA CHAINSAW & BLOWER (A58374)
HUSQVARNA CHAINSAW...
