Buying a Farmtrac 665DTC...should I?
   / Buying a Farmtrac 665DTC...should I?
Thanks for the heads up Clint. That's sounds worth an oil drain.
   / Buying a Farmtrac 665DTC...should I? #32
From looking at the parts breakdown, it don't appear that the 555 DTC and 665DTC have the same transmission, case, gears and etc. Maybe someone has more knowledge about these tractors than I do. I did look at the 665DTC pretty close and I don't see an inspection cover on the side of the rear end case. However, I do see a round cover on the 555DTC rear end picture.
   / Buying a Farmtrac 665DTC...should I? #33
Could very well be, I have never seen a 665, just going off my issues with the 555. Just assumed and you know what they say about that.
Maybe it is different enough that I won't have the problem. I did check the parts manual breakdown and I see the pinion bolts, doesn't appear to have any lock on it. When I'm back over at the farm I'll take a look at the inspection cover.
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 BMW X5 AWD SUV (A56859)
2013 BMW X5 AWD...
