Buying a Farmtrac 665DTC...should I?
   / Buying a Farmtrac 665DTC...should I?
Thanks for the heads up Clint. That's sounds worth an oil drain.
   / Buying a Farmtrac 665DTC...should I? #32
From looking at the parts breakdown, it don't appear that the 555 DTC and 665DTC have the same transmission, case, gears and etc. Maybe someone has more knowledge about these tractors than I do. I did look at the 665DTC pretty close and I don't see an inspection cover on the side of the rear end case. However, I do see a round cover on the 555DTC rear end picture.
   / Buying a Farmtrac 665DTC...should I? #33
Could very well be, I have never seen a 665, just going off my issues with the 555. Just assumed and you know what they say about that.
Maybe it is different enough that I won't have the problem. I did check the parts manual breakdown and I see the pinion bolts, doesn't appear to have any lock on it. When I'm back over at the farm I'll take a look at the inspection cover.
Vermeer Mixing System with Hose Reel (A55973)
Vermeer Mixing...
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused CFG Industrial MH12R Mini Excavator (A57453)
New/Unused CFG...
