butchwalker9
/ butchwalker9 #1
genesis12
Ridgeville, SC
JD4300
Can someone help me with my JD-4300 it won't start unless I remove the fuel cutoff solenoid, push in the plunger and replace the solenoid. This is very time comsuming so I bought a new one replaced it and it worked for about 3 months. Took the original one replaced it back and it worked for about a month. I have tried moving around the fuel cutoff relay and that didn't have any effect. HELP!!!
/ butchwalker9 #2
It has 3 wires red white black .red should have power with switch on .white wire has power on it when you go to start the engine is the only time it has power on it. It is what pulls the sol in red holds it after it starts. You need to check to see if you are getting power to white wire with switch in crank position.
2016 Ram 5500 Flat Bed (A63688)
2016 Ram 5500 Flat...
40' Shipping Container (A66285)
40' Shipping...
2020 Deere 544L (A60462)
2020 Deere 544L...
Case International 21' Disk Harrow (A64127)
Case International...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
