""" BUSTED"""
/ """ BUSTED""" #1
NCGMAN
NORTH CAROLINA
YANMAR
:D Well this is what happens when you try to press the bearing out of the wrong end!!!! :( My stupidity.. The seal on the blade end looked like it was part of the housing,,, so "I" put it on the press upside down... Oh well ,, live, work and learn. I've pressed out a lot of bearings in my day,, but this is the "first" time this has ever happened to me..
OK!!!! YOU ALL LET ME HAVE IT !!!! GO AHEAD SAY IT!!!! I CAN TAKE IT.....
/ """ BUSTED""" #2
Hey, nice work! :D
I've certainly broken my share of things that I'm supposed to be fixing.
Vic
/ """ BUSTED""" #3
Don't feel bad. I did almost the same thing repairing my Kubota drive axle. I was trying like mad to pull the bearing off the shaft. I checked an double checked and I was positive I had the direction correct.
I put a larg-ish crescent wrench on the puller and went to town. I shattered one of the links on a 3 ton puller! The bearing sill didn't budge. THAT is when I got suspicious of my thinking capabilities. I did another check and sure enough I was pulling against the bearing seat. It was just a tiny step on the shaft and I didn't see it. I should have mic'd the shaft on both sides of the bearing and I would have known for sure.
Good thing is I think there are plenty of parts available for these tractors. Good luck and keep plowing forward. You're going to whip that tractor into shape in no time!
/ """ BUSTED""" #4
I think that you need a new one! :rolleyes: I would say let him who has NEVER pulled a bone headed maneuver in repairing something to be the first to ridicule--The rest of us just say well that did not work--but we are smarter now and go on. :D
Mike
/ """ BUSTED""" #5
OK, I''ll say it then: HOW COULD YOU BE SO .......................honest?
/ """ BUSTED"""
I had to let you all know!!! Because out there is someone that has done something just as stupid. You know guys; when I do something like that I really don't get upset, I just go on and start over. I've learned it dosen't do any good to rant, rave, cuss and throw things. Besides all that could cause you to have a Heart Attack :(
/ """ BUSTED""" #8
#1. We live and learn from our mistakes. You are alive and you learned from your mistake. Life is Good.
#2. When we make those mistakes we learn not to tell everyone.
/ """ BUSTED""" #9
and #3. When we learn from those mistakes, we don't always tell others about it so that we can watch them fail too, and then somehow feel better about ourselves.:D
/ """ BUSTED""" #11
Vaguely reminiscent of the one we did. I could say you stole my picture but we didn't take one. I think the end result would be similar regardless of which way you tried to press it out. It sure don't hurt to try though. Good luck on finding a replacement.
/ """ BUSTED"""
Gonna try Agri Supply in Greenville. I do believe these mowers were made for Yanmar by Woods. Can't hurt to go look. Oh that place is like Christmas shopping...
/ """ BUSTED""" #13
Take the old one along with the blade bolt to make sure it matches. Good luck! Let us know if you find one.
2015 LeeBoy 8510C Asphalt Paver (A61572)
2015 LeeBoy 8510C...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
10-16.5 Skid Steer Wheels and Tires (A61572)
10-16.5 Skid Steer...
