Bush Hog
/ Bush Hog #23
Here they are called rotary cutters. We have had 5 different brands, and the Brown is by far clearly the best you can buy- expensive but the most durable and reliable we have had
/ Bush Hog #25
I've never heard a BSM called a rotary cutter...
These days, I use my rotary cutter a lot more than my BSM.
SR
Doesn't the engine turn the blade by rotating a drive wheel?
Doesn't it cut by rotary action?
When you say "rotary cutter", many people don't know which type of machine you are talking about.
Most understand what type a brush hog is.
/ Bush Hog #27
Who cares....life is too short.
And if the crescent wrench strips off a bolt....sometimes you need a sawzall. But that's why I like Allen wrenches/bolts. Can't bugger them with a Crescent wrench. Channel locks maybe?
/ Bush Hog #33
LD1 made a clever sentence with tools brand names instead of actual names and I understood every single bit of it and that prove his point.
I got the part about the different tool names, but I guess I have never had anyone ask me for an adjustable wrench or a reciprocating saw or hex head socket or slip joint pliers, just used to the slang terms I guess, but I think most people are.
/ Bush Hog #36
I know I'm being picky but I have an issue with folks calling a rotary mower a Bush Hog. Bush Hog is a brand name just as John Deere, Ford, Dodge, etc.
Home - Bush Hog This is the Bush Hog website note they even call them rotary cutters. I know it may be a hard habit to break but could we learn to call them rotary cutters unless of course you are referring to the Bush Hog brand.
The mark of a good brand name is that it becomes used as a generic name for the kind of product it is. Bush Hog has achieved that. So has Kleenex, and, to a lesser extent, Coke, Frigidaire, Bendix and a few other brands.
/ Bush Hog #37
Get over it! It was originally called a Stock Cutter for chopping Corn Stalks prior to plowing in my area of Ontario.
/ Bush Hog #38
NO. Stock Cutter or Bush Hog. You're welcome.
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2013 KENWORTH T800 WINCH TRUCK (INOPERABLE) (A65643)
2013 KENWORTH T800...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
