Bush Hog Squealer
/ Bush Hog Squealer #41
<font color="blue"> (SQ84T) the blade tip speed is 11,500 fpm where as the SQ720 blade tip speed is 14,963. I wonder what makes the blade speed so much different? </font>
The 84T has 2 sets of blades?? If that's right, then each set of blades will be about 42" diameter, tip to tip. The 720 single spindle set-up will be about 72" diameter. If the 84T gearbox doesn't turn the blades at a significantly higher rpm, the larger diameter model will have the higher tip speed.
If my numbers are right, the 84T is turning about 30% more rpm than the 720. The smaller blade diameter, however, translates into slower tip speed, despite the higher rpm.
Just a guess.
OkieG
/ Bush Hog Squealer #42
I have the sq720 with a slip clutch, on a New Holland TC29
It works great, it's just a little bit wider then the tractor and that makes it easy to guide in small places. I will tell you that look at buying a finish mower first, unless you will be cutting alot off brush. A field cut with a finish mower looks better.
/ Bush Hog Squealer #43
</font><font color="blue" class="small">( woof,
What is an LK3054? I don't get out much, so pardon my ignorance.
)</font>
AN LK3054 is a 30 hp Kioti. They are Korean and usually sell with more standard options then the big three for less $$$, I know that's why I bought mine.
Adams Tilt Trailer (A61307)
Adams Tilt Trailer...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
BOX BLADE (A58214)
BOX BLADE (A58214)
