Bush Hog SQ84 cutter
/ Bush Hog SQ84 cutter #1
TxSam
Dumas, TX
LS MT357C
Anyone have experience with this cutter? I can get a used one for about $500. Does that sound like a reasonable price?
From what I know it has two blades, each blade has its own gearbox and it has two rear wheels instead of just one, I believe it is also lighter and shorter overall than the SQ72. I'll be using it with a NH TC35. Any feedback is appreciated.
Sam - Tractorless in Big 'D'
/ Bush Hog SQ84 cutter #2
<font color=blue>...I believe it is also lighter and shorter overall than the SQ72. I'll be using it with a NH TC35. ..</font color=blue>
For $500., if it doesn't need anything... absolute bargain...
However it's bigger... not smaller than the 72"...
Also you may have approached or went past your limit for a TC35, unless you're strickly using it to mow grass and not brush... and it's a heavy implement... have front weights and loader to keep the "nose" down...
{it should only have one gearbox on the Squealer series}
/ Bush Hog SQ84 cutter #3
Great mower for that price. New they run close to 2000. I like them because they don't tend to scalp as much as full round decks and they don't stick to far back from the tractor. Depending on what you are mowing I think you are buying a handful and maybe more as far as your tractor is concerned.
/ Bush Hog SQ84 cutter #4
I agree that it sounds like a bargain. John, according to their web site the SQ84T is available with a choice of single or double spindle. And it's wider, but shorter, than the 6' model. I'm not sure about the dimensions of the older models.
/ Bush Hog SQ84 cutter #5
<font color=blue>...the SQ84T ...</font color=blue>
I assumed it was the standard 84... the T is very rare and between a finish mower and rough cut... and not as heavy, or as long... well someone hand me a towel please, to wipe this egg off my face... /w3tcompact/icons/smile.gif
But, it's still a bargain @ $500.! /w3tcompact/icons/wink.gif
Sorry about that, you slipped a post in on me./w3tcompact/icons/smile.gif
Egg... what egg... Just good constructive discussion in my eyes! No problem! /w3tcompact/icons/wink.gif
John - It is definately the two gearbox model, I may have the wrong model number though. It is also shorter than the 72" since it has two blades intead of just one. As I think about it though, I'm not sure if it is heavier or lighter than the 72". I may have been thinking more in terms that since it is shorter that the counter-weight effect wouldn't be as pronounced. I'll look into it a little further and keep you posted.
Sam - Tractorless in Big 'D'<P ID="edit"><FONT SIZE=-1>Edited by TxSam on 12/07/01 09:18 AM (server time).</FONT></P>
/ Bush Hog SQ84 cutter #7
Sam,
If anything... buy it to resell it {as long as everything works}... I'd venture to say, you could easily double your money if it's right... /w3tcompact/icons/shocked.gif
John - /w3tcompact/icons/shocked.gif is right! I just thought it would make a good rough cutter. I was originally thinking of getting a finish mower but the cost was prohibitive. If it gives a good 'in-between' type of cut I'll be ecstatic! It just needs cleaned up a little and maybe a little PM (preventative maintenance) and maybe sharpen the blades. Is sharpening these type of blades even possible?
/ Bush Hog SQ84 cutter #9
<font color=blue>Is sharpening these type of blades even possible?</font color=blue>
Yes, I sharpened the ones on the last Bush Hog SQ48 so many times, I finally replaced them with new blades. So far I've only sharpened the ones on the Howse I now have once. Getting the blades off some of the brush hogs isn't too bad, and getting them off others is all but impossible./w3tcompact/icons/wink.gif So a lot of folks sharpen them with an angle grinder without removing them. Of course you don't want them quite as sharp as the blades on a lawnmower; preferably leave a flat front edge of approximately 1/8". Of course if I were only mowing grass and weeds; no brush or woody material, then I'd sharpen them a little sharper.
Thanks Bird - Sounds good to me! /w3tcompact/icons/wink.gif
We'll see how it goes!
Round Bale Livestock Feeder (A66408)
Round Bale...
Wooden Glider Chair (A64557)
Wooden Glider...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
